Hmm.. the 300ohm HD6XX also prefers the high gain setting even though the volume knob needs to stay below 9am. Simiarly to the other headphones, the high gain seems to improve the top-end and openness of the sound. And actually I'm quite liking the pairing of the HD6XX with the SP200, ends up being quite a musical combo.
My xDuoo TA-30 I was using with my Focal Utopia went a bit faulty and is having to be returned. I already had an SP200 in my downstairs set up which I had been mostly using with my Focal Stellia but occasionally also the Focal Utopia. Tested with the Utopia extensively once it became apparent I was going to need something else.
Honestly more than delighted with a SP200. Clean, powerful and transparent. Allows the Utopia to shine. Ordered another one for the other set up .
Got a good deal on one and agree, solid build, good performance, no issues with my volume knob, in fact channel matching is really excellent down to the lowest volume level. Looks like SMSL have fixed whatever issues there were with the volume control on the earlier builds. I will likely use it for a second setup somewhere else in the house.
So I just got my new Hifiman Arya today, and I need a new DAC / Amp or DAC + Amp. Im looking at SMSL M200 DAC + SP200 AMP VS Topping DX7 Pro DAC/AMP
Which one would drive the Hifiman Arya better? any infos would be appreciated.
I have the Arya & SP200, loved this combination! When your budget allows it, also try the Topping A90, the difference is much larger you would expect from only 200$ difference, especially with balanced Arya's.
guys, please excuse my ignorance, but when I connect my DAC to the SP200 through dual XLR, will I be able to use the quarter inch output still or must I listen through balance XLR? Is there a significant sonic advantage in using dual XLR vs dual RCA? Thanks a lot!
