imkenny
- Dec 10, 2011
I'm not sure of the idea of burn in. Do all headphones typically have a burn in period?
It is generally accepted (I use the word "generally" so as not to start a flame war with skeptics) that for most headphones, a burn-in period of about 100 hours is usually when a headphone will have reached its full potential. However (questions about the existence of burn-in aside), some cans take up to 300 hours or more, and some sound the same right out of the box that they always do. I personally believe in burn-in from testing two white-boox Audio-Technica ATH-M50s side-by-side (after a friend bought one new) and finding the mids much fuller and the bass more controlled on my pair than their new ones.
Sincerely,
Sincerely,
Have you done blinded (or even better, double blind) ABX testing to confirm this?
Just throwing my two cents in, I wear glasses and i find the massive plush pads of my Brainwavz HM5 very comfortable. They also seem to isolate from noise quite well. It has a neutral sound to it with a pretty nice soundstage.
Does the HM5 come with velour pads as an accessory (I didn't think it did, but I'm just checking). From what I've heard, velour is better for glasses.
The HM5 do not come with velour pads unfortunately, just a spare set of leatherette pads. The Fischer Audio FA-003 however come with a spare set of velour pads, and as far as I have read here they should be the exact same headphone. However the Fischer's should be a bit more expensive. I think you can order the velour pads separately though and they should fit the HM5 just fine.
