linuxworks
Member of the Trade: Sercona Audio
- Oct 10, 2008
amarra is said to modify the timing between pulses (I reckon).
what else COULD they be doing? they can't mess with amplitude or value of each sample. they won't resample (no one wants that).
the only thing LEFT is the microtiming between pulses.
I suppose its possible to change that, but from software?? sounds very unlikely to me. timing between pulses is part of the *transmitter* chip in spdif. you can't change that on the fly. and if you did, you'd be over-riding the local oscillator clock. sounds like a thing you would Not Want(tm) in any way shape or form.
I have not seen a satisfactory explanation of what amarra does. until I see something that makes real sense, I have conclude its also snake oil.
Originally Posted by Sherwood /img/forum/go_quote.gif F All that "Bit Perfect" implies is that the digital signal generated by a piece of software is passed in its entirety, without modifications, through the digital output of that system. Amarra modifies the signal before it is outputted. |
