The HD600 is the closest you're going to get - in the Sennheisers - to the legendary HD800, and because it has been "one-upped" twice, it's priced at a terrific discount. Like the Grado RS-1, it has been around long enough to have survived the cloud of hype that hovers over every new product. People don't buy these former flagships unless they like the sound. Look at this FR Graph comparing the top Sennheisers with the Grado PS1000:
The HF spikes on the HD600 are nothing like an HF spike on a Grado, though there's one place where the HD600 is the brightest of the Sennheisers, and that's between 2.5 kHz and 5 kHz. Even then, it only peaks above flat by a few dB - from 3-4 kHz. As spikes go, this is pretty marginal, particularly up against the 10 dB spike of the PS1000 at 7 kHz. In fact, this baby spike is less intense than the HD800's baby spike at 6kHz, though more noticeable because it's closer to the tonal center. When the HD800 has its baby spike, the HD600 is 5 dB below flat.
Sibilance tends to be associated with higher frequencies, such as 8 kHz and beyond. Yet from 4.5 kHz and beyond, the HD600 remains below the line. If you're experiencing sibilance, it's either the track, the source unit or the amp. Some recordings are sibilant on purpose. The engineer wanted to give the track a certain sheen to compensate for the HF roll-off of FM radio. Some tracks - especially from the 80s - are gratingly sibilant. On the other hand, if the amping is anemic, you'll get sibilance. I get it off of my HD800 if I listen to it from an unamped iPod.
Bear in mind that if a vendor is selling headphones that are dark, altering the track or source to make it brighter is to be expected. The material Bose uses to demo its headphones is carefully selected to showcase what strengths there are and to hide sonic deficiencies. In fact, I can take a pair of JVC Marshmallows, which are dark and bassy, and EQ them to something much more acceptable, thereby hiding minimizing the deficiencies and showcasing the presentation. It's deceptive but it happens.
You need to listen to the headphones in question from a variety of tracks. If you can swap out their source for yours, you're better off, but don't forget to amp the headphones properly. Otherwise, you'll get a tonal imbalance. Under-amped 650s sound dark and veiled. Under-amped 600s may seem tinny (That's at least the result with under-amped HD800s).
