I'm not sure about the KRKs though... I think they really missed the boat with
those (at least with the 6400). I've had some VXT-6 and Rokit 8s (in the end I ended up with Tapco Monitors)
and I really liked these cheap monitors for recording sessions at my house or at my friends studio.
Anyway, I was hearing a lot of good things about them and went to my local musicshop
and they had them (along with some Sonys) so I decided to try them. I could not listen to half an hour
with the 6400... it was grainy as heck, clarity was not at great and for the price I would have preferred the Shure 440s
(sounds fuller, funner, overall better!). Basically, for tracking they could be Ok, but for a simple mix, no way. Their
sound is way tinny.
Now, I believe the 8400s are very good for their price. Everything that the 6400 lacks the 8400 fixes.
The grain is not there on the highs, the mids are fairly consistent and there's enough low-end to not
only track but do a proper mix. These will not replace nearfields/monitors (nor any headphones in my opinion)
but they do a good job.
Thing is, side by side, the Shure SRH940s EAT both of these up in terms of comfortability,
clarity, soundstage and
extension (normal listening, not recording). Recording wise... not sure yet. Only tried once to track and
mix with mine and the result wasn't that good (probably due to the headphones tendencies to favor the highs...) so I definitely
need to try a few times and see.
For
music listening between the SRH940s and KRKs, I definitely choose the Shures.
For
recording sessions (at least tracking and initial mix) I would have chosen the 8400s.
I guess it will depend on your priorities, what you are looking for and whether or not you are prepared
to spend a bit more or not. But for example, if you get the KRK8400 at $150, buy an extra coiled cable ($12) and an extra
set of earpads ($30-ish) you are closer to $200 so... again, to me the Shures are in a great place.
And if anyone can find them open-box for $170 (like electronic expo had them), even better!
Thanks.
P.S. Just in case, I'm not a "real" musician hehehe, just a hobby. Though I have family members who
are and have CDs out, etc. hence my time in the studios and stuff. I like that but don't have enough
to create full-on songs, just create ideas and record them
