Shure SRH1540 Review
Apr 13, 2014 at 11:25 AM Post #361 of 2,683
  from my experience yes - though the initial harshness was easily 'cured' by turning down the volume to a gentler level. after a day, things started to change, even non-audiophile friends of mine started asking how much is the 1540 after trying them on - before the 1540, they almost always just tell me i'm crazy to be spending too much on cans.  I still do find it better on gentler volume levels.
Been driving it with ifi dsd + ifi itube + ifi ican.  There was noticeable (for the better) change with the itube buffer specially when set to +6db.  I could tolerate the bass to a higher volume level - unfortunately, it doesnt seem to cope well with a lot of strong dubstep records i throw at it.  But then again i dont really listen much to dubstep music - i just wanted to hear how it will deal with the strong and ever-changing bass of the genre.
with vocals (mostly female) and instrumentals i like it very much - smooth and detailed. Although as i have said in some other threads, it sounds somewhat 'airy' for me for a closed back headphone - maybe because of the pads - which might as well be why sound leakage is bad at slightly above volume levels.   Now that I think about it, at volume levels where sound leakage is minimal but volume is just enough - the 1540 sounded most enjoyable for me.
and also, the carbon fiber is just too cool :wink:
hey there, i noticed ur signature u mentioned u have iDSD, is it good? currently i feed my srh1540 from pc -> schiit audio vali -> srh1540, currently looking for a fairly priced and good dac at the moment, so how do u connect it? is it usb from pc to iDSD then RCA to desktop amp?
Apr 13, 2014 at 5:07 PM Post #362 of 2,683
for the short period that i've had it, yes. it drives all of my headphones alone well sans the hd800 (ok this is not my hd800 yet - a loaner from a friend but mine's arriving tomorrow).  Transparent and has decent punch for it's size.  The battery life is decent but it can be improved I think.  And yes, It's usb to iDsD then RCA interconnect to the amp - it has 3.5 mini jack output, but i only use it when it's by itself on a mobile setup such us my C&C portable amp.
If your pc doesnt have really clean USB power output, I suggest turning the iDSD first before plugging it in so it will use internal battery power.  It sounded more veiled running on usb power from my mac book pro - and the mid-bass isn't as good when running with battery power. It may be my long audioquest cinnamon usb cable at fault there.  But like I said, on battery power, it is a whole lot different ballgame. It is that apparent to me that I decided to buy iUSB as well so that i wont have to worry about running out of clean power when plugged.
It is the best bang for the buck out of all the ifi products IMHO given you can use it for a low impedance mobile setup as well - yeah the amp section is decent enough to be usable, but i dont think the amp section will replace your vali. I dont own the vali but i've listened to it for a few minutes from a store.  If you get the iDSD, let me know how it pairs with the vali on the 1540.  if you love it, i may pull the trigger on the vali although i have the iCAN which is another little wonder on its own.
Apr 13, 2014 at 11:43 PM Post #363 of 2,683
hi, thanks for the input, but most probably not going to buy it so soon because overspent on audiophile stuff in the past 1 month
Apr 22, 2014 at 9:08 PM Post #364 of 2,683
Does anyone have trouble with the fixed angle of the ear cups/pads?  I tried the SRH1540 at a meet and loved the sound, and the pads were the nicest I have ever tried... but like the V-Moda M-100, the ear cup angle is fixed.
Looking down at the top of someones's head:
is how the feel to me, when what I really want is something closer to this:
Do I just have a strangely shaped head, or do some of you have the same issue and have solved it by bending the frame slightly inward towards the front side of the ear cups?  Just wondering.  I find it hard to get used to because I am consistently bugged by the uneven pressure towards the back of my head rather than the balanced pressure I feel with my ATH-ESW9 or HD-700 which both have pivots that allow the ear cups to angle in to match my ears and/or head and thus feel balanced and less fatiguing for longer listening sessions.
Not takers on this???  Just one more attempt to get some feedback from those of you using this headphone...
I think I have the same issue, the fit is odd (just went through the 1st 8 pages of the thread, don't think I have the time or patience to go through the whole 25, sorry if this gets covered later). I have a small head, ears must be somewhat unusual as well, because I'm always struggling with fit, Iem's tend not to fit me well on the left, had fit issuess with the Mikros 90. The poor fit often results in loss of bass, the way it does on iem's when they don't seal well. I've read everywhere how the bass is just fantastic on the Shures, and it is anemic when I listen. If I hold the cups/pads against my head, it comes back. I think the back of the cup doesn't fit flush against my head, ruining the seal. Are there other pads someone has tried that might help here? I'd ask if anyone else had a similar experience, but Greggo seems the closest to my experience. I've bent them a bit, the upper part that the headband slides through starts to irritate my head, and I hate to deform them too much. Any ideas? Thanks
Apr 22, 2014 at 9:25 PM Post #365 of 2,683
I think the alpha pads should be thicker, so it should help for smaller pads. I think. I don't know for sure.
Apr 23, 2014 at 10:42 AM Post #366 of 2,683
I probably have it a bit the other way around:
Face
Back of head
I have experienced problems with some headphones with limited movement around the vertical axis, but Shure SRH1540 seemed fine.
InnerFidelity's Tyll Hertsens writes and talks about this and how to bend the headband to get a better fit in his review:
http://www.innerfidelity.com/content/cool-comfy-and-competent-shure-srh1540
Apr 23, 2014 at 11:15 AM Post #367 of 2,683
Yeah... they still haven't learn how to fix that with their headphones.
I don't really have problems with them, but I know lots of people do...
Apr 24, 2014 at 7:22 PM Post #368 of 2,683
Well well. Here's by favorite SRH1540 rig.
RWAK100(not that RWA mod matters)
Carat-Topaz(via optical in)
SRH1540
People say carat topaz is bad when compared to modern dac/amps. I say not. Having owned one of the most competent amp/dac(uha-6s.mkii), I can say carat topaz perform at that level. It also matches 1540 well.
Apr 24, 2014 at 7:23 PM Post #369 of 2,683
Wow, sorry for overlooking this post. I have Alpha pads on mine, and I helps immensely with isolation and fit.
The catch, however, is getting that good fit. For my head, the angles need to placed facing upwards and the headband needs to be stretched. Its real tricky and people should be advised of so.
In the end, the ft will look as:
Dome
Chin
Edit: I have pics around here, somewhere
Apr 24, 2014 at 9:21 PM Post #374 of 2,683
I felt that way the first month I had them, until I got some Alpha pads
Well, I'm aiming for 1k hps now. I'm also selling my RWAK100 to fund for this.
Apr 24, 2014 at 9:23 PM Post #375 of 2,683
  Sorry :p. I still love them, but I just want better.
I hear you and that's why I'm saving up for the TH900's but I plan to keep the 1540s too.
