325xia
- Mar 8, 2015
This makes total sense. Maybe I got too much IEM for my player. I uses use AFLAC files on my iPhone 6. But, I have read and heard from others with this combination that they sound amazing. So, I will give it some more time with them. Thanks for this detailed explanation.
iPhone 6 isn't a bad source. But if you're in this hobby for a while possibly check out iBasso DX50 or DX90, Shozy Alien, see if you notice any improvements. The DX50 won't break the bank and should let you know what's going on. If it doesn't work out - you do whats best, nothing worse than sticking with something you're underwhelmed with.
Before I go, I'm curious which Sennhesier IEM you're talking about?
This is good advice. Maybe, I will get the DX50. Thanks for the info.
I'm comparing them to my also new, Sennheiser IEM Momentum's. They also got great reviews here on Head-Fi. They are amazing for the price. IMO
I'm not sure i would recommend se846 with dx90.I find se846 has great synergy and musicality with sony players,the new a15 would be a good choice without breaking the bank or fiiox3,x5.I wasn't too impressed with the pairing with dx90 imo.
I loved the synergy with my Fiio X3, sounded very very good. I often paired them with my X3 over my 240.
I've been listening to my iPhone 6+ with tidal lately and have been super happy with the performance. Can you stream tidal with a&k players? I just find it super convenient.
