Shure SE846 Impressions Thread
Sep 7, 2014 at 9:48 PM Post #5,957 of 22,954
same tips, same filters.
Maybe it is the slow increase of sweat/condensation/dander that has accumulated in the damper foams of your filters that has changed the FR, sound signature, and as a result, possibly sound quality from when you first listened to the SE846, 'til recently.
Sep 7, 2014 at 10:01 PM Post #5,958 of 22,954
Just to clarify, I've only had these for a few days, brand new out of the box. I've had the other one for a few months. Maybe I'm just used to the bass.
Does anyone else have a moto X? The hissing was really loud on my first one, but the hissing is very quiet now on the one I got recently.
I'm not complaining, just a little curious.
Sep 7, 2014 at 10:08 PM Post #5,959 of 22,954
bobby12 Oh, well in that case, I'm not sure, haha. The Moto X just may not be a good fit for the SE846 impedance-wise. Have you started to troubleshoot by trying any other smartphone or DAP to find out if there were any similar issues with hissing?
Sep 7, 2014 at 10:25 PM Post #5,960 of 22,954
Yeah the moto x is horrible for all my IEMs :). You can hear the hissing for a few seconds after a text message from the SPEAKERS. I just wanted to see how loud the level of hissing is on other se846s with the moto x
No hissing through the iphone or dx90. Friend is borrowing ak120 but there shouldnt be any hiss on that either.
Guess I'll just listen for a few days and see how it turns out.
Sep 7, 2014 at 10:29 PM Post #5,961 of 22,954
Well, then there's your answer. Not trying to get you into another/different phone, but I know several members on this thread (as well as myself) think the audio from the G3 is very good.
Sep 7, 2014 at 11:34 PM Post #5,963 of 22,954
Still doesn't solve my bass problem. Well, time to get the SCS!
I love my moto x screen size too much. It's perfect so I never want to upgrade:D
In that case, since you are okay with the hissing from your beloved Moto X, just increase the EQ in the bass range (for example 60hz) in your favorite media player, and that should take care of your bass wants and needs. The SCS may help you out with your bass needs as well, as the deep fit and isolation should maximize what you hear in the entire audio spectrum, but of course, your mileage may vary.
Oh, and the Moto X's (2014 version) screen size is 5.2 inches whereas the G3 is 5.5 inches, for reference. :bigsmile_face:
Sep 8, 2014 at 3:46 AM Post #5,964 of 22,954
You'll be bashing the ie800 the minute you put the 846 in your ears.
Maybe...Maybe not....I own both and I like both ....yes the 8s are better :..it hits lower in the sub bass region which is what I love ....but I still found myself liking the iE800 it's a nice IEM in many ways plus it's an innovative move forward it may not be perfect as nothing is I think even the 8s could've been made with a better seal between the nozzle as there's stronger yet forgiving materials that could've been used ..... But I tell you after hearing them you will fall in love with the Shures ☺️
Sep 8, 2014 at 7:48 AM Post #5,965 of 22,954
For me the Westone star tips work perfectly for exercising. I also used the active comply tips, which were actually very good as well. Surprisingly. I prefer the Westone over everything else I've tried. At least until I add sleeves.
Did a little research on the Westones...seems they come in silicone and foam. Which one are you guys recommending? The silicone ones look like every other silicone type so what's so special? Is the silicone thicker than the stock silicones? Also, not sure they will work with the Klipsche x10 ear buds I have now.
Sep 8, 2014 at 8:05 AM Post #5,966 of 22,954
I bought the DX90 because of hissing problems from my moto x. Now I don't even know what I'm doing anymore lol
Oh nevermind, I don't even have enough space on my moto X. Guess I'll keep one player around.
The westone ones have more sizes and extend longer. Playing with it right now, the silicon feels more flexible
Foam is less painful, but takes longer to put on and gets dirty. Silicon is more painful unless you get used to it and doesn't get dirty as easily.
http://www.amazon.com/gp/product/B00DD2BZRY/
You can buy this and try all of them if you want. I don't know if it will fix the klipsche though.
Sep 8, 2014 at 8:12 AM Post #5,967 of 22,954
It will fit the Klipsch earphones. I use the Klipsch oval tips on my SE846s.
Sep 8, 2014 at 8:55 AM Post #5,968 of 22,954
The Westone Star silicones have "ribs" of some sort on the inside that are supposed to help them keep their shape, etc. You can see them on the inside. But I do find I get a better more secure fit and better sound with them vs the stock Shure tips
Sep 8, 2014 at 9:22 AM Post #5,969 of 22,954
Ah, I see those..thanks. I ordered the "combo" kit with foam and silicone tips. For $16, it seems like a good move at this point. Thanks all...Scott
Sep 8, 2014 at 10:07 AM Post #5,970 of 22,954
Yes, I apologize. I wasn't bashing the 800's. It was a slight disappointment being a supporter of most high end Sennheiser products in general. A lot of universal iems come down to fit. The bore of the 800 just wasn't stable in my ears.
On another note, if you like westone star tips, I highly recommend trying meelec double flange tips. They sit a little bit deeper in the canal without intruding on any frequencies. They also are very comfortable. To me, they are a step above the westone tips in terms of comfort, fit, and sound quality.
