M Coupe
- Dec 20, 2012
Wow. Now I know the Roxanne is way too big for my ear. The 846 is a tight fit.
And thus is the line between addiction and passion (albeit a very fine line).
On a side note would it not be possible to put a Custom Sleeve on a Roxanne and have the "best of both worlds". Thou I can't imagine JHA endorsing it through a recommended third party. They would, I imagine given their size, REALLY stick out..
I really need my SCS back. "Resting" my ears is like watching daytime television.
I use my 846 4+ hours a day to include heavy uses during workouts. Has anyone had any issues with the stock cables? Does anyone have any recommendations for a heavy duty aftermarket cable for workouts? I've looked at a lot of after market cables but none of them look like workout cables.
OKAY! I have heard enough of the SE846. I figured it all out and I will be sending them back and maybe considering W50 or W60.
Bottom Line: I listen relatively loud to really engage myself into the music (but certainly not deafening volumes). Regardless of how good the bass is and even the midrange clarity of SE846 which is also excellent.....there are 2 issues that no tip or amp or EQ will ever cure that do not sit well with me.
1. Midrange is too forward for my tastes (but this is what Shure does).
2. There is surely an upper midrange spike I do not like.
Combine #1 and #2 with decent volumes and you have a very fatiguing earphone. Granted, I am not ripping Shure or anything, this is just my personal take based on the kind of sound presentation that works for me based on my music and listening habits. But it is also well worth noting. I stick the W40 back in my ears and yes, it is darker...but the treble still shimmers and it is SO much easier on the ears and quite frankly....just as engaging. Being lighter is also a plus. The better bass of SE846 is not enough to trump W40. I am not sure I would even trade SE846 straight up for W40. It's that close IMHO.
Really not much else to say other than I am sure Shure invested a lot of R&D in making SE846 but based on what you get with SE535 at about $400....man, I just do not see a over double price upgrade EVEN considering the law of diminishing returns which I am well aware of.
I will re-iterate from earlier post, the SE846 has nothing on the JH13 or JH16. Not even in the same class. It is simply a SE535 with a subtle subwoofer while still maintaining EXCELLENT clarity. Nothing more.
I might say be careful trusting ANY review where a reviewer was comped the IEM's. Huge bias going obviously.
IMHO if my W40's had a little bit more clarity in the midrange it might be the perfect IEM. It is soooo close to perfection. Bass is fine.....maybe 20% less abundant as SE846 but just as textured and detailed, no question. Let's not forget...when they made W4 it was about a "better" more detailed and textured bass (2 drivers) with a very transparent and neutral IEM. Then with W40, they bumped up the bass about 15-20%. What more would a person want?
On my way to go research W50 which would be waaay easier on the pocketbook.
The stock would be the best to work out with but I would not recommend working out with expensive earphones.
Yeah, to each his own on soundstage. I like it big. I like a big sound and a big soundstage without resorting to high volume.
For me, the 846 is decently wide and nicely deep and off-set from my ears. I don't like the sound to come directly on ear location (slightly behind is okay). I had it on random play today (as I drove) and an old Supremes song came on with the bass off to the side. I had never heard the song before and I looked around because I wasn't use to bass coming from far to the right side.
I also like the holographic imagining that has improved (for me) with the black filter. It adds a little weight for a better 3D-like effect throughout the spectrum. I max out the Viper4Android room size to get that whole thing to work. I now have a renewed interest in the Roxanne to compare.
Otherwise it's like drinking expensive Belgian ale through a beer bong.
I just started laughing at "It is simply a SE535 with a subtle subwoofer". Legit belly laugh.
I'm sorry you're not a fan, but if you can't hear any difference between the SE535 and the SE846 except a "subtle subwoofer" then... well, godspeed and I hope you're happy with whatever you land on. I bought the SE535, upped to the SE846 and did not even for a split second consider going back.
As for your whole thing about volume and energy, I'm constantly listening to metal with these things. Yes, they have a bit of a bump at around 8KHz with the blues in (did you try the black?) but it's far from a spike.
Also I'm not even sure what you're saying. First the mids are too forward, then there's a spike in the highs, then all they did was add a subwoofer. If the first two were truly problems, then the added subwoofer would have fixed a rather EGREGIOUS problem with the SE535s in that they'd have big mids and fatiguing highs with no lows. Based on what you said, the SE535 must be a TERRIBLE headphone because it sounds exactly like the SE846 with its overly forward mids and fatiguing highs but NOT the bass. Yikes, they must be awful! But then you say they aren't worth the upgrade?
So let's review (based on what you said):
- Excellent clarity
- Subwoofer-like bass
- Potent mids
- Strong highs
Fatiguing is a personal thing, and again I'm sorry you find them that way. It's now 9:14pm, I put mine in around 9am today and took them out periodically when the day required it, but I'll generally have mine in for 10-12 hours a day listening to books and music, and unless I'm absolutely cranking the volume I feel good about it.
Once again, if you don't like them you don't like them, I just find the criticisms you're leveling against them rather incoherent.
PLEASE! Put the bong down! Did you read my post? The Shure mids are forward and that is the house sound regardless of what the bass is.
There is an upper mid spike instead of naturally extended highs. That is the Shure house sound! Please find ANY DATA to dispute these two truths! and find me data showing SE846 is anything more than a SE535 with a subwoofer. I'm still waiting after a year now.....
I did the original review here on HF on the first SE535 6 years ago. Owned the SE535 two times for a total of about a years worth of listening so I know what I am talking about. I have no reason to bash Shure. I have been to their factory about 40 minutes from my home. Have owned E2, E3, E4, SE420, E5, SE530, SE535, SE846. I was very specific to NOT say, the SE846 sucks....but to explain what I personally did not like about it.
Again, if you took the time to read my post, I was VERY specific saying that these were my findings and not gospel and golden rule for everyone. Listening (and reading) is a skill. Work on it. As a newbie, you probably don't realize I have some crediblity here after 12 years and dozens of reviews. And as a newbie you might learn that you have similar likes and dislikes and hear things similarly to other posters. These are the posters you want to follow and identify with. It can be very helpful and can shorten the learning curve (and money expense) in finding the best thing for you.
I'm glad you found your holy grail. My comments are just one man's opinions....but surely valid opinions. Lighten up son.
