- Aug 22, 2015
I have used a setup very similar to yours, but I have not experienced headaches. How loud are you listening? Have you tried lowering the volume?
Maybe just around 40-50% for the Volume, not too loud actually. But i don't know why i feeling headache after 2-3 hours of usage. I just don't want to damage my health because of this. Does anybody know what the reason behind this headache??
@PerfectCircle
have you tried the Star tips? did it make any change? or do you still feeling headache after changing the tips?
i have tried star tips and its the best tips compared to all the stock ones but still i get headache and my ears start hurting after few hours of listening, but a big plus to star tips for comfort they are great. mby 846 just doesnt fit my ears or smthng
Just speculating a bit here, but universal IEM's may not be for everyone. It took me a long time to get used to them, fooling around with tips, and they still aren't the most comfortable thing in the world. I greatly prefer headphones. When I finally settled on the tapered foam tips, the comfort level was better although still not perfect.
I think that's why so many folks get custom molded inserts (is that the right word?) made for their IEM's. Custom inserts will certainly fit better and be more comfortable. Just my thoughts.
Best -
RCB
+1. Settled on the foamy Shure olives with the wax guard removed. Best comfort and amount of treble to my liking. As you said, the fit is not perfect, and I literally have to change the foams every two weeks because they lose their compression properties very quickly. Even the spinfit tips of all sizes let me down. Considering Sensaphonics' custom molds, but it is too much work
The approximately ten minutes out of my day I spent getting impressions created for my Sensaphonics Custom Sleeves made all of the difference for me, as zero sizes-fit-all tips worked for both of my ears, especially since one of them is cauliflowered. Saying who has the time to get a mold made is ridiculously ludicrous, especially when it takes less time to get them done than getting another IEM or sizes-fit-all tips to try out, in my opinion.
For those that are having headaches from their IEMs with the sizes-fit-all tips they are using, and do not want to try getting custom sleeves, then some headphones that are lightweight may be a viable option for listening to audio.
So, what would a change of filter means?
I would say changing tips would be like changing their outfits, changing filters is like putting on make up
From reading people trying out westone tips on the 846, I'm guessing they are compatible with each other?
