As far as I can remember, I have never seen a fake SE530 before, even on Chinese forums I frequented. Also that is not 0162, but 0167. It is a date code Shure uses to identify the date of manufacture. In this case, this particular IEM is produced on the 16th day of 2007. The significant thing about the date code is that Shure announced the rename of E500 to SE530 on CES 2007 (6th or 7th Jan). The two IEM looks identical, but SE530 date code is 'xxxx SE530' instead of 'xxxx'. That being said, I think there is a good chance this is a late production E500, or one of the earliest SE530. One of the tell-tail signs is that the olive foam tips on teh IEM itself has no dots in the base to indicate size. Shure added the dots in a later time (olive is 'officially' announced on the same CES 2007, but Shure added it in E500 package since late 2006. Also, that is not an E500 or SE530 case, but a E5c's case (Shure EA625). Also, I didn't see any extension cable in the picture, which will be bad because SE530 / E500 has a two part cable design and it will be too short without the extension cable.
My suggestion is: avoid this. Though it is probably a real E500 / SE530, the age of the IEM itself makes it much less appealing. The questionable accessories issues are certainly not helping either.
