TYATYA
The pic is my tip on kse1500.
Made from 3 components
1. Shure stock foam tip
2. Spinfit cp145
3. Spinfit cp800
Best sound for me after many tried.
White dust filter seen in the pic is from stock black foam. It helps on treble adjustment.
You will hear black foam has less spark in compare to rubber stock tip.
One of reason comes from this filter.
Cut it off if you need more spark on black foam.
(2nd reason is diameter of tip's hole).
With dust filter, sound stage is larger than all shure stock or single flange spinfit tip.
Stock spinfit gain low and highs, so apply a dust filter is suitable.
