Mm...about 8 hours, with spare. Past 12 months of use, I've never run out of juice.
Shure KSE1500 Review - Shure KSE1500 Sound Isolating Electrostatic Earphones
- Thread starter jude
or bring a portable batt like a very small one. It can charge your KSE1500 and your phone at the same time. play all day long and enough batt left to make 911 call in case you need it.
of course I meant to play from the DAC directly connecting with camera connection kit with power and data port
Shure or bust
- Jul 24, 2015
What are the best eartips ?
West tone premium audiophile eartips (Foam) - For bass and extreme isolation... as good as custom. This is a longer foam
Mimouille
I use Westone star tips.
Roscoeiii
Anyone have a rec for a good case that can fit both the KSE1500 and a Chord Mojo?
Doesn't need to be big enough for a DAP, since I use my LG V10 phone or a desktop computer as the source.
Jwm48324
- Sep 21, 2010
Just sent out my custom impressions to sensaphonics for my custom tips for the Shure 1500.
does using a Mojo with the KSE make any improvement in sound quality? (comparing to just the KSE's internal DAC)
Roscoeiii
Great combination.
yeah, the Mojo is a nice sounding little DAC. But is it really worth adding? (since KSE itself also has the USB DAC function )
spook76
- Jan 13, 2013
I second Roscoeiii's recommendation. The slight warmth of the Mojo pairs wonderfully with the KSE. Also, Rob Watts of Chord Electronics design ethos, namely, accurate transient response is exactly what the KSE's electrostatic aim to deliver.
DiamondD
- Dec 8, 2016
Where would you get one of these for less than the 3k price tag?
Total: 6 (members: 0, guests: 6)
