plakat
@Pablovi for me AAC provides a perfect balance between sound quality and connection stability. Therefore I object on the "only AAC"
aptX and especially aptX HD are much too sensitive to limited available bandwidth -- which makes its use problematic in areas with lots of active Bluetooth devices (and compress anyway, making hi-res even less attractive).
I think technically iOS/iPadOS sees theAonic as an external soundcard, so if the software is able to take advantage of that soundcards properties, it should be able to negotiate parameters beyond default iOS settings. Yet I'd not expect that minuscule DAC to take advantage of the possibility to get away with a much simpler analog filter (vs the filter with CD resolution), so I don't think there's much in that...
