It is too early for me to make a good and fair comparison, even because I have a Tanchjim Tanya comming soon, so I can try its black filters on the ej07m. I am also going back and forward with tips, and they seemed to have opened up a bit with burnin (brain or otherwise). Initially I found the ej07m fatiguingHow would you say the EJ07m compares to the LZ A7 with the black filter? I really love the LZ A7's with the gold and black filters, but I've been looking to take a leap to a higher end IEM, and so just wondering how the A7 holds up.
I was expecting a massive sound improvement from the ej07m, and that didn't happen yet. In fact, for many tracks (e.g. Cory Wong albums) I prefer the
[EDIT] - It turns out I was suffering from the same resonance weirdness than was first reported by @redrol (his review is a better account than this write-up. btw). I finally got the Tanchjim Tanya and used its dampers on the ej07m, resulting in the somewhat contrasting edits below. All the fatigue is gone after using Tanchjim dampers, and my impressions of the ej07m are now generally much better (almost 180º turn). I should also add that tweaking the ej07m with dampers, grills, etc. was fun and they do respond really well to tip rolling.
Treble - Extension is about the same as the LZ A7 (it is great on the A7). The ej07m has better timbre, accuracy, resolution, effortlessness, but the LZ A7 has more bite (and so does the LZ A6), it is probably a piezo thing. Still, I prefer the ej07m for orchestral, and that was my number 1 use case for it. I also prefer the treble of the ej07m to that of the EST 112 due to its better extension.
Bass - The ej07m's sub-bass resembles more of a subwoofer, which is very satisfying
[EDIT] - Using tanchjim dampers means that the higher mids loose the weird focus, and the bass texture, especially that of the upper bass becomes very satisfying. Though impactful, the bass of the ej07m does not encroach on the mids in any way. It tends to sound like good bass in a good venue, with good sub-woofers, and reverberations that convey room size information. It is not there if not called for, and is well integrated with the earphone's dynamics and the rest of its sound signature. I still think that there is something to be said about the EST 112's mid bass resolution, that is still better and quite adictive, imho. The LZ A7 is not a contestant in this race, though it does not disappoint either.
Mids -
[EDIT] - With Tanchjim dampers, these just sound silky smooth and natural, yet exquisitely detailed, throwing everything else out of the park. Guitars are extremely natural, horns spot on, with all the little details on display (air movement, clacks of keys pressed, etc). The EST 112 has a different flavour of this, with more evident macro detail and micro detailed pushed slightly further back, but the ej07m conveys the same information through different layers, and does that with better dynamics. The LZ A7 has excellent mids, but the detail, texture, layering with which the ej07m envelops its delivery of mids is just on another level.
Soundstage - The ej07m kills it completely, no contest.
Imaging - ej07m has ridiculously good imaging, it is something special.
Practicality - I thought it was harder for an earphone to compete with the LZ A7 in comfort, but the ej07m is extremely comfortable too - it is really tiny! However, sleeping with the ej07m is not great because of the rather annoying and loud driver flex, though the shell shape is good for that.
Build - Driver flex is really a major downside of the ej07m, imho. It is annoying, you listen to it every time you adjust the earpieces, and detracts from the premium feel of it. The metal shells of my $50 CCA CKX seem to be put together better than those of the ej07m - the seems of the faceplate of my ej07m are a bit wonky... hard to spot, but again, this is supposed to be a premium product for the price, even if the "m" stands for mass-produced.
[EDIT] - Using foam tips cut in half (like @redrols) mitigates the driver flex, though I personally now prefer how the ej07m sound with Spinfits cp145. Driver flex is an allmark of the ej07 series, and should be expected. Once the earphones are in place there is no more flex, and I was assured by @redrol that it doesn't damage drivers. Might be a small price to pay for such an amazing bass.
