Starfinder
My Tape left iem is now running quiet, going back to amazon.
Try keeping it for a night after using a blow drier on it. Once I faced this issue, I guess it was due to moisture build up. The above solution worked for me.My Tape left iem is now running quiet, going back to amazon.
Twisting and pushing your foam tips to get them flush with the nozzle opening on your EJ07 is a very bad idea. I have some cracks in my nozzle. Luckily they sound the same, but you have to be very careful, when you twist and push the tips.
Moving the filter toward BA driver will decrease the damping of the filter, thus more high mid frequency response.Yes i could, but i had sandpapered the nozzle, so you can see not much. I can descripe what i done. I removed the filter of the estat drivers and pushed down the mid driver filter with a toothstrick. The filter is now there, where the triangular mid driver chamber begins. It sits on top of the triangular chamber. But you have to be very careful. When you push it to far, the filter get loose and falls down in the chamber. When you have done this, the sound is more detailed, because of the removed estat filter and it sounds more timecoherent. I have a spherical soundstage. I can hear things half a meter away from me. The singer is in front of me instead in my head. The imaging is more holographic. I'am very happy with this result. Please be very careful with this mod. Try at you own risk.
Sorry to hear. What are you using to push the tips? I've swapped out the filters multiple times and with the removal tool I had no issues.
I have my mid filters flush to nozzle (same as when I got it)
Edit: oh you used a toothpick? Be careful not to break the mesh
You can use damper with lower ohm value instead if you don't want to take the risk that pushing the damper too far, it should give you the similar result.
this method of tuning is discussed at sonion's 'Designing Earphones with Balanced Armature Receivers' document.
https://www.sonion.com/wp-content/uploads/Documentation_Designing_Earphones-1.pdf
I pushed the filter on the edge of this little metal thing, not the mesh. If you removed the estat filter, then push the filter, that sits flush on the nozzle, down to the top of the triangular chamber. If you can take a photo of your nozzle with the driver, then i can mark you the position of the filter.
