I never had a problem connecting the KSE1500 to any iPod/ipad.
did you tried to out the phone in airplane mode?
Hissing Noise!!
Anyone experienced any hissing noise when using the KSE1500 through USB?
Hissing about 1/2 sec to 1-2 sec in some songs, then returns normal.
My setup
OnePlus 5 > USB-C OTG Adapter > Cable (USB~MicroUSB) > DAC
Application: Spotify - Normalize Volume OFF, Gapless OFF, Offline Mode ON
DAC: USB Charging OFF, Equalizer FLAT, Audio Limiter OFF, Fireware 1.2.2
Does anyone if it is problem with my setup? wrong OTG adapter? faulty DAC?
Line-in have no problem. Any help is appreciated.
May I know if the Shure KSE1500 needs to be burned in. If yes, any recommended number of hours? I find the sound quality revealing but can be rather bright.
--------------------------------------------------------------------------------------I talked with the distributor today, they attribute the problem to the quality of the Cable.
Since my setup is below:
Phone > OTG Adapter (USB-C to USB) > Cable (USB to Micro)
The distributor says they see alot of problem with USB styled headset, and many just have bad connections.
USB-C is even worst, as quality of cable and feature of cable varies alot.
Those mini adapter Micro>USB-C is basically useless. Some cable only charges, no data sync.
Some charges but not up to 3Amp....etc
I am waiting for below cables to arrive for testing, hopefully it will be solved.
- Belkin P-F2CU033
- First Champion FC-TC2BM
I have some measurements I've been itching to share for ages and I'm afraid I just can't hold back any longer...
A while ago on this thread @ohotonge shared some measurements: https://www.head-fi.org/threads/shu...tatic-earphones.785377/page-149#post-12588674 which garnered a bit of controversy. Some (i.e., Jude) heard the KSE1500 as having a "rich neutrality", while these measurements showed a fairly intense resonance peak around 10 kHz. Some folks above have been talking about finding the KSE1500 a bit bright and I've noticed that too on occasion, when using my favorite SpinFit tips. Some love the Sensaphonics custom sleeves - others, not so much. I recently made some measurements of the effects of different tips on the SE846 and the results surprised me - the differences were in some cases larger than the effect of changing tuning filters. I thought it would be interesting to do the same for the KSE1500:
Here are the measurements using REW and a Vibro-Veritas coupler with my StarTech sound card, and no EQ (flat) on the KSE1500 amp:
Now my measurements probably won't agree with others who've used different sound cards, mics, couplers, measurement software, etc. However, my measurements are repeatable and the deltas in terms of dB between eartips should be comparable. (Despite the above differences, my measurements with SpinFit tips are actually somewhat similar to those of Ohotonge's, give-or-take a slight shift in insertion depth <=> slight shift in resonance peak.)
Some thoughts:
1) What a difference a tip makes! In certain frequency ranges, the differences are larger than anything you could compensate for with the parametric EQ.
2) Sensaphonics custom sleeves are (for me) a total disaster. Now, everybody is going to have different SCS, so maybe they'll work for you, but in all likelihood, you'll see a drop in frequency and an increase in amplitude of the resonant peak due to the effective increase in bore length. Again, this might suite your preferences, but neither of these effects are something I'd want. They sound awful to me.
3) Comply foam and Shure olives result in a pretty similar FR.
4) SpinFits extend the low end (that's good), but also the treble - and perhaps by more than one might like.
I can totally see how somebody using Shure olive tips would hear a rich neutrality, whilst somebody else listening to the exact same track, from the exact same source, doing nothing different but using silcone tips, might hear something which is too bright.
Some thoughts:
Can you test the triple flange sleeves? how do they compare.
