kiler
- Mar 26, 2011
Yeah I'll probably will I am in the dire need of a DAP :b Even though the Zero sound awesome out of a smartphone.
More than 200 hours of burn-in are over.
My initial impression hasn't changed much - good in-ears but clearly on the bassier side of balanced (esp. in the upper bass), coming from the UERM/ER-4S/SD-2/MR3. Strangely I find them somewhat v-shaped - not only in the upper treble, but also in the middle highs around 5 kHz where the graph shows a dip, I hear a peak (probably a resonance in my large ear canals). Tuning is quite well done though.
Great bass control and speed. Good minute detail retrieval although the mids aren't the sweetest (but nicely detailed though). (Really) good performance for the price. Can compete well against other dynamic driver in-ears below $200, but is about on the same level as other (dynamic) in-ears that I consider as excellent budget offerings (comparisons to budget and higher priced models will be found in my review).
Good overall impression.
So let the casual and then the critical listening phase begin...
on what daps tho?
DX80, DX90, Geek Out IEM 100, UHA-6S.MKII
ergh try a phoneand direct from laptop/ PC
^ this does matter, considering the price tier
Why that?!
A laptop's output is definitely not on the weak side, in terms of quality and power, so as phones.
[...] but I did do some listening directly out of my laptop's headphone out [...] and actually found the mids definitely became more present. It turned more V shaped sound as soon as I plugged it into any amp.
Maybe a certain level of power changes its sound signature? I'll need another few days to say for sure.
Consider people who would buy a $50 Bucks iem, such is more realistic....
Phones have pretty ''safe'' tunings and rely more on the DAC output than analogue amping, more control for this type (zero) of iem....
And the tuning is not aimed to please audiophiles. (just imo here)
Daps used to have higher gain/ amping considerations thus and so there is more need for pairing (also a tendency to match with some iems, vice versa.
Just try anyways, this should give it more justiceDo get it tested on iphone if possible
http://www.lg.com/us/laptops/lg-gram-15Z960-A.AA75U1-ultra-slim-laptop
Huh? Yeah they are... I really doubt any laptop can put out more than 80 or 90mW of power, and even if it can, it's going to be at a very low resistance, like 10 ohms. On top of that, it's going to have a miserable DAC and be noisy!
IMO a laptop is even worse than a smartphone in terms of quality to expect from it. A desktop computer is equally bad IMO.
I don't understand what you mean by "in terms of quality and power, so as phones." though
