- May 3, 2009
While I haven't done any research on how will this kind of product will sell. It will not be much cheaper for the manufacturer to make as you need design a system that is robust enough to withstand the abuse of general consumer, yet not too bulky to kill your neck (LCD2 cough).
For such a system, I can only foreseen a headphone with removable earcups and only retrain the headband while swapping. That way the parts will be big and strong enough and hard to lose. A headphone driver bare is extremely fragile and easy to lose. Any kind of clip on closed back cover will need to be secured, while for a circular headphone, a screw-on system can be used.
From an engineer's point of view, the product is just making the job harder without saving any cost. And in fact increasing it by a fair bit. Unless one is prepare to pay the same price as two headphones.
For a consumer product, lots of loose spare parts is a big NO. People will start losing drivers in no time if one is to swap from closed/open often enough. And even then, switch a complete closed back headphone to an open back headphone will be far less time consuming and you are not likely to lose a whole headphone rather than a drivers size of a large coin.
IMO, this idea only works for the novelty factor and not practical for both the consumer and the manufacturer.
