Which seller it was? Can tou send me link to PM? My black headphones from aliexpress are definitely the first versionYou can order V2 from AliExpress, but before you place an order, you have to contact with seller first, "they ship it worldwide i think".
I've just bought mine (black color).
the seller has reply me: ok, if you want V2, please choose black color.
So for someone who want white or Red color for V2, probably still not available..?
Shanling MTW100 - True Wireless IEMs, IPX7, BT5.0 Balanced armature or Dynamic driver
Oh, that is a shame. I've used mine in the shower 4 times so far and they're going great. I stick my head under the water but I try not to get too much prolonged, direct spray on them. So far so good.Yep.
After bathing in the shower the touch control on the right earphone stopped working. After about a week the control began to work but a terrible hissing sound appeared in the earpiece. Totally disapoint
you as children, read the ipx7 protocol, provides for a short dive. But these are headphones and the sound needs a passage
thesheik137
That's too bad because I was planning on swimming with these.
I actually ordered these recently, despite vowing to never go Bluetooth and if I did it would have to be ldac or aptx due to IEM/codec snobbery.
Looking forward to seeing what Shanling came up with even with AAC and only 1 BA.
Hey, Shanling. I hope when you return from the holidays, you can answer me the question - where can I buy the mtw100 v2 with delivery to Russia?
You can find our Russian distributors at our website: http://en.shanling.com/category/354
Otherwise you can order from our Chinese dealers, such as Shenzhen Audio, Linsoul, etc. You can message them ahead to checkif they have V2 in stock.
Can confirm the misodiko TWS-Joy tips work great with the MTW100, here are some pics of mine:
The iem's sit flat in the charging case, and similar to the spinfit CP360's (SS are still too big for the case) they hold in your ears much better than the stock tips.
Thanks for confirmation on compatible tips! Might get few of them myself.
Anyone else been using these in the shower?
I sometimes use them, but always make sure to clean them dry after shower. While they are waterproof to some degree, it has its limits.
Yep.
Please try to put them into bag with some fresh silica gel, to make sure there is no water left in them.
As waterproof as they are, there are some limits what can be done with earphones.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Recieved mine a few days ago (v2). Very pleased with them. Sound is exactly how I imagined it would be - quite neutral and very detailed. Although I must say they are on the quiet side - I use them on ~80% volume mostly. Ordered misodiko tws joy tips as its hard to get a good fit with the ones supplied with the earphones. Hearthrough works OK for the price, the sound is very metallic. Case is ok. I like how small it is and the fact it has wireless charging. But the earphones stop and start charging again if you shake the case. Not really a big problem.
Does anyone notice a difference between SBC and AAC on android phones? I use them on Xiaomi Mi 9T pro with sm8150 chipset (snapdragon 855). I dont really notice the difference between 2 codecs. Maybe the AAC sound a bit more congested (although it says in the bluetooth settings of the phone that AAC is "high quality mode") but maybe Im imagining it. I listen to FLAC recordings on deezer hifi
Anyone tried both the Shanling MTW100 and the Mifo O7?
I'm struggling between these two and wondering which one has the better sound quality... Both have great reviews and are in the same price range.
I've owned some Shanling DAPs (which are great company IMO) and several pairs of good/TOTL IEMs, but now looking for a decent sounding TWS (especially for work/commuting).
Anyone can help?
Anyone can help?
Anyone can help?
Isn't price on O7 like 170 USD? So almost double of MTW100?
Here in Canada, both are priced around 120 $CAD...
Adapada
- Oct 4, 2009
Having some trouble getting these working in stereo mode all of a sudden. The right bud powers on and says '2 earbuds pairing successful/connected' but the left earbud does not say 'power on' or anything. Slight hiss from the left and normal operation on the Right earbud. I can get the MTW100 L to show up by taking just that one out of the case, but it does not say power on or play any music.
I've tried factory resetting but I can't seem to solve the problem, and can't figure out if a factory reset actually triggers.
Any help?
Any help?
Any help?
If you are getting no sound at all from left side, it might be some hardware problem on it. Unfortunately only way how to solve it would be to contact your seller for warranty repair/replacement.
ColdsnapBry
Will these stay in my ears at the gym? Thanks!
Depends what exactly you will be doing, but it should be fine most of the time. Just be sure to choose proper fitting eartips.
Anyone can help?
I dont think mifo uses knowles driver so theres that. And those generic balanced armature drivers dont sound as good. But then again there is 2 of them so you would probably get a more versatile sound but probably not as detailed.
Also, mifo o7 advertises anc but they dont really have anc. And they dont have hearthrough mode. Volume control is a plus, something I really miss on my shanlings.
Side question for the shanling representative: is there any future posibility to get volume control through firmware update?
Thanks for your comment. I finally pulled the trigger on the Mifo O7...
As an (quite picky) audiophile, I don't expect to be blown away by these to be honest... But heh, we'll see.
Didn't tried many Bluetooth stuff in the last 7-8 years, so I'm a bit curious to see if there is a significant improvement in the near 100 $ market now...
I plan to use it mainly at work/for commuting, so something sounding toward the neutral and versatile side could fit the bill.
