What is UAPP?Have you tried using UAPP? If that works for you just disable the native music player. If you have an Android player, there's no reason to use the native player - UAPP is the best there is, by far.
Shanling M8 Android Portable player
- Thread starter Shanling
- Tags
- shanling shanling m8
@Shanling, just wanted to mention again that I keep having this problem where all of a sudden the music just plays verrrryyyy slowwwww... and if I just pause and start it, it goes away. But it happens often.. sometimes it happens about once an hour, or sometimes a few times per hour... any thoughts?
What is UAPP?
UAPP is for USB Audio Player Pro, a licensed app you can install on Android through the play store or the APK if the player allows it.
When I type USB Audio Player Pro into APK, I do not see it in search results...UAPP is for USB Audio Player Pro, a licensed app you can install on Android through the play store or the APK if the player allows it.
nickwerner
I think apkpure doesn’t work as this is a licenced app (i.e. not free). You need to obtain it through google play store as far as I know.When I type USB Audio Player Pro into APK, I do not see it in search results...
all999
Because it's available in play store only and You have to buy it.
Oh I didn't notice the APK versions I found weren't fully legit and I would recommend against it and sticking to the Play store.
pv815
Recently purchased the WP900 and the AP2000ti. Had some high end Audio Technica headphones a number of years ago and frankly like that they are still made in Japan.Hello,
has anyone had or has the opportunity to test the M8 with
ATH-WP900?
regards,
Simon
The WP900 sound great with the M8 and with all genres of music. I have been using the Neutron Player with DSD and Flac files on my M8 and the staging is quite good with any of the headphones I have used but the WP900 detail retrieval and the accurate bass once I put 20+ hours on them was what I had expected and was not disappointed. Seems to me that the mids were a bit recessed out of the box but not any more. The M8 feeds them well and for me a welcome change/up to iems even when traveling, love them.
Quadfather
So, are any users having any issues or difficulties with the M8? Has anybody tried it with Sennheiser hd650 Headphones?
Yes, I have seen a lot of manufacturers make last minute changes to upcoming DAPs (etc) because of it. Really difficult situation. I guess the M30 might be affected as well.
We have enough supply of AKM DACs for M30, it will not be affected by this.
Hello,
If I understand correctly this M8 has no line out? Because I want to connect it directly to my tube amplifier.
regards,
Simon
No dedicated line-out circuiut or output connector, but you can switch it into line-out mode and use it with external amplifier just fine.
I reported this to our software team, but so far they were unable to replicate it.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Quadfather
I really want to try the M8, but I cannot get the Sony NW-WM1Z out of my head that I demoed. Wish I could find an M8 in Chicago area to demo.
Vitaly2017
ask @MusicTeck send them an email they might send you a M8 demo if they have one on hands
gonzfi
- Dec 22, 2012
Offline qobuz. It basically doesn't work when saving music to a memory card.
simon740
@ pv815Recently purchased the WP900 and the AP2000ti. Had some high end Audio Technica headphones a number of years ago and frankly like that they are still made in Japan.
Thank you for this info. Very helpful.
regards,
Simon
Vitaly2017
Is that qobuz related? Is tidal and spotify working in offeline?
Total: 9 (members: 0, guests: 9)
