Stu Paddasso
You should also try the Hiby music app it works really well on M8 also.
Thanx, just installed and scanning my library right now.You should also try the Hiby music app it works really well on M8 also.![]()
I just purchased the M8! Should be here next week. I'm also using Hiby on my M6 Pro, and I agree with your comments. Also tried UAPP and didn't like it as much. The main reason I use Hiby is because it will hold multiple custom EQ settings, unlike the Shanling music player.I ended up with the Hiby app- thanx @Stu Paddasso ! To my ears it doesnt change this characteristic for M8 fluid and wet sound sig but it only elevates dynamics and bass in comparison to the original Shanling app. It also has gapless and many nice functions which i dont use haha.
So to sum up- SQ wise the Hiby app is the Shanling app on steroids but retaining same controls and even tuning, its just bit cleaner.
The UAPP is great too but it makes the M8 sounding more like an AK, more reference but still very pleasurable.
Neutron with 16x oversampling sounds very slightly denser in hights (after many careful tests so its almost on the edge of perception for me) but the bass becomes bit weaker so its a no go for me.
I EQ most all of my headphones. Nothing is perfect out of the box from my experience, so I prefer to dial them in closer to what my brain and ears really like.With M8 you not need custom Eq settingsAll frequency are perfect. Ok for my ears
