mRaaghava
- Sep 29, 2016
Did anyone compare M8 to Cayin N6ii R01 module?
I am glad that you continue to support the M8, but with the new FW:Firmware V1.5 for M8 released
Mainly system performance improvements
Full notes and download link at our website: https://en.shanling.com/article-M8v15.html
We are not seeing any issue with Idle Power off?I am glad that you continue to support the M8, but with the new FW:
A) idle power off no longer seems to work, and
B) the Shanling Music App is still a mess - it cannot sort artists alphabetically (The Rolling Stones come before The Beatles). That really sbould be a very simple coding fix. Gapless playback? I have given up on that....
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
I had it set to 10 min all day yesterday. It never turned off. Stayed on all night. Will try with one minute.We are not seeing any issue with Idle Power off?
Please what time you have set there? Can you try to set it to 1 minute?
Nope. Still does not turn off.I had it set to 10 min all day yesterday. It never turned off. Stayed on all night. Will try with one minute.
I know system wide eq will deactivated the bit perfect but will not do Downsample because all streaming services play max 16 bit 41 khz.System wide EQ will require resampling, and hence the data retrieved from the source is no longer bit perfect.
There is no other way around resampling to allow digital EQ, period.
So, whoever is telling you that their system bypasses Android resampling and is bit perfect from the source, and is also EQ available system wide….those are full of **** they are fooling the users, period.
It sounds not only great but amazing with my 7hz timeless.Hey if it sounds great why do you need to EQ it????
EQ is not the way to do it man, you just need another player to voice up well with your other headphones. That is the fun in this hobby.It sounds not only great but amazing with my 7hz timeless.
Eq is needed when I use the wrong headphones with it . For example I must tweak the sound if bass anemic or not enough Treble energy with some headphones .
HeyWhenever I felt like needing equing I ve been using UAPP - working flawlessly on M8, more stable and more versatile than both Shanling native player or Tidal native app
