Shanling M6 PRO - Dual AKM AK4497EQ DAC, New Improved Amplifier, 600 mW Output, Android OS, Snapdragon 430CPU 4GB, 2.5 & 4.4 Balanced
Jul 13, 2020 at 1:51 PM Post #91 of 293
Update for Shanling Music app will be available through Play Store.
With iOS version it's complicated, we will tell you more when we can.
Yes, coming with next run! (In shops end of July/early August)
Matte glass on back quite helps with fingerprints.
Dear @Shanling,
I proudly have my M6 pro now, bought in Germany for 1 week and I am very happy with the sound so far.
Nevertheless, being an ios and pc user so far I am slightly confused by Android.
What's installed on my device:
current M6 Pro firmware: 1.31
Shanling App: version 1.9.2
Android 7.1.1
Some issues I am facing, not sure whether I am doing anything wrong:
1. how to install Google Play store properly (it was not installed on the device)? I loaded it through APKPure, as I did not find any other way, installed it, but I cannot sign in. The system does not react at all when I try to sign in.
2. will a detailed manual be provided for download?
3. Streaming of my favourite station "Radio Paradise" always stops after while playing which is quite annoying (sometimes after one song, other times after 2 or 3 songs); then I click sync and my favourite channel and music continues playing ... and so on.
I set data usage to WIFI only (what is Wifi + Cell good for?), cache autofill to even 5 hours 30 mins
Is because of Google Play Services missing?
4. When listening to my FLAC files (thru Shanling app - UPnP) stored on my NAS all songs of an album are sorted in alphabetical order, specially with concept albums like "Amused to Death" this is not much fun.
5. Now Shanling Music app keeps stopping - error message "Shanling keeps stopping ==> close app"
6. While it was easy to pair my iphone with M6 pro via bluetooth, nothing else can be done - no Bluetooth device control nor any set up
7. Factory reset does not work as described - no image of green robot but only a couple of commands, turning the volume wheel in little stepy is not possible, as it directly jumps from reboot to power off
At the moment I am a bit frustrated, honestly, as I spent a lot of time already.
Your help should be very much appreciated.
Apologies for my imperfect English capabilities.
Thanks
Sylvia
Jul 13, 2020 at 10:13 PM Post #93 of 293
Dear @Shanling,
Android 7.1.1
Thanks
Sylvia
1. Send you private message.
2. You mean manual for our Shanling app? Or for whole Android system? We have some set-up guide on our website: http://en.shanling.com/article-M6Setup.html
3. This app? https://play.google.com/store/apps/...are.android.radioparadisewidget.gpv2&hl=en_US Did you contact the developer of this app with your problem?
4. Will check this with our software team.
5. Can you provide little bit more details? Like during what action does it happen (playing from NAS< playing some certain files, etc)?
6. To use SyncLink controls, you need to have Shanling Music app, which is currently available only for Android.
7. In this menu wheel is more sensitive, so you need to be little bit more precise with it.
Hi everybody . Can I connect a B&W PX7 headphones on M6 Pro whith usb cable on M6 Pro usb port ? Thanks
This headphones works in usb mode on a windows PC and an Ipod pro 2020.
Not sure, are these made to be used with Android device over USB-C?
They might connect to M6 Pro as any other USB DAC, but in that case you would need to be able to control volume on headphones directly.
Jul 23, 2020 at 9:19 PM Post #100 of 293
Jul 24, 2020 at 5:54 AM Post #103 of 293
It remains to understand which one suits me.
I will also ask in this thread if someone used the M6 / M6pro with Sony IER-M7?
Want better sound with more balanced presentation, can one day use the more powerful output and have extra cash? M6 Pro.
Or prefer slightly thicker/warmer sound, don't need to run demanding full-size headphones and would like to put 250$ towards other hobbies? OG M6.
For example headfonics have nice section comparing M6 Pro and M6: https://headfonics.com/shanling-m6-pro-review/2/
