northixora
How can i go back to Firmware V1.4? help pls
https://en.shanling.com/article-M3XV14.htmlHow can i go back to Firmware V1.4? help pls
Will try it soon.. thank youhttps://en.shanling.com/article-M3XV14.html
Should be able to get zip from here, save to top level internal storage and do local update.
Hello, I need your advice, here I can, how much is the maximum memory with an external card for the shanling mx3, I will buy a memory soon and I need to know the maximum that can be used, I await your response, thank you.New Firmware V1.5 for M3X.
Range of fixes and improvements.
Full notes and download link at website: https://en.shanling.com/article-m3xv15.html
OTA update available.
In theory current card format supports up to 2TB cards.Hello, I need your advice, here I can, how much is the maximum memory with an external card for the shanling mx3, I will buy a memory soon and I need to know the maximum that can be used, I await your response, thank you.
Hi,
For some reasons my M3X is fully charged at 99%. Does anybody experience the same issue ?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
you can try power off the unit and charge., happened to me few times while charging with the unit on. Power off, charge and youl'll get 100%Hi,
For full size headphones I would really recommend going with M6 21 or M6 Pro 21, they give it much more.Hi,
does the M3X have enough juice to drive a HiFiMan HE400i 2020 or even a Sundara?
I usually listen to music at *moderate volume*.
Thanks in advance for your help.
Does the M3X support gapless playback or by any chance could be possible to install an app that could make it work?International release is planned for March.
Currently there is no gapless in Shanling Music app. But other apps can work gaplessly.
It's supported by other music player apps from the playstore like neutron and uapp and I think also by HibyDoes the M3X support gapless playback or by any chance could be possible to install an app that could make it work?
This is an amazing stack <3
Shanling M3X line out to XD05 Bal and then CCZ Plume.
Main difference that i noticed by adding XD05 Bal for the amp part over M3X:-
>The output has better extensions, especially in the lower end.
>The bass punch gets real with the XD05 Bal in the chain, this is the biggest change that i notice in the sound.
>While the output is clean with M3X itself, but via the XD05 Bal it is cleaner.
>Width and other dynamics are more or less same with or without XD05 Bal in the chain.
