Shanling M3X Portable Player - Our smallest Android Player
Jul 4, 2021 at 10:46 PM Post #1,216 of 2,445
I just received my m3x, so far so good. Only thing I am a bit disappointed is that I can’t use SyncLink with my iphone :frowning2: hey @Shanling , any plan on implementing this for ios devices???
Yes, we have plans for it. But as with other things on iOS, it's not that easy.
That silicone case...does it come with normal M3X as well @Shanling ?
We do not make silicone case.
Another question guys. When I was listening my songs for the first time I remember seeing MQA logo and blue dot under the cover art. However today (same song) I can’t see any indicator under the cover art as you can see from the screenshots below:
First screenshot shows that the song is an MQA file but you can see in the second screenshot it doesn’t show a blue dot or mqa logo. I am not sure if I changed a setting or something. Has anybody noticed this?
On our devices it works as it should. Getting MQA icon and 705.6kHz sampling rate in status bar.
There is no setting in our app that would affect this.
Jul 5, 2021 at 2:56 PM Post #1,218 of 2,445
Jul 5, 2021 at 4:15 PM Post #1,220 of 2,445
I downloaded and installed it but it still uses bluetooth for connecting even though it is connected through usb c
Yeah, I just tried this driver too. Not working for me either. @Shanling could you please link the correct driver to the M3X Downloads page.
Anyway, once the correct driver is installed. Plug the M3X into the PC then on the M3X pull down menu click on SD Card and Change to USB DAC.
Sorry this driver isnt working.
Jul 5, 2021 at 9:08 PM Post #1,221 of 2,445
Using Bluetooth for connecting? That's completely different function and has nothing to do with USB input.
Did you switch your M3X from Storage to USB DAC mode? (Accessible in swipe down menu)
There is just one USB Driver for all our portable players: https://en.shanling.com/download/69
What exactly do you mean by "not working"? M3X not switching to USB DAC mode, or it switches but you get no sound, not showing on PC, etc?
Jul 5, 2021 at 9:22 PM Post #1,222 of 2,445
Ahhh my bad, didn't realize that the storage option could be changed to DAC mode. Works perfectly now, thanks!
Jul 5, 2021 at 9:36 PM Post #1,223 of 2,445
Jul 5, 2021 at 9:57 PM Post #1,224 of 2,445
Received my m3x (limited edition!) last week and have been enjoying it! It seems like a great deal so far.
However, I am having an issue where downloading albums from streaming services (Spotify and Amazon Music) to the SD card seems to cause the apps to hang indefinitely. I saw @Shanling mentioned an issue regarding downloading albums to the SD card earlier in the thread. Is this the same known issue?
Jul 5, 2021 at 10:51 PM Post #1,226 of 2,445
Software team recommends to use only internal memory for downloading these files for offline playback.
Actually I spoke too soon, it seems to be connected but when I try to play any kind of audio, it does not make a sound and then the device shuts down by itself
Yes, we are getting such reports from some users. Hoping to have it fixed with next firmware update.
Jul 6, 2021 at 12:55 AM Post #1,228 of 2,445
Hi @Shanling, is the sample rate that appears on screen only available by using the shanling app and certain apps? When i use hiby music the sample rate doesn't change according to the song played.
You mean on the top display bar? If so, mine changes according to the song, and I am using hiby too
Jul 6, 2021 at 1:11 AM Post #1,229 of 2,445
Yes, the one on the top.
Mine doesn't change once it reaches 705.6khz. The next song has 44.1khz and it still showing 705khz
Jul 6, 2021 at 1:36 AM Post #1,230 of 2,445
Are you running something with MQA? Seems some app by accident got M3X stuck in the 16X MQA mode or something?
