Shanling M3X Portable Player - Our smallest Android Player
May 15, 2024 at 2:24 AM Post #2,446 of 2,512
Sorry to hear about this, sounds like the potentiometer in the wheel gave up.
If the unit is under warranty, you can reach out to your seller for warranty.
If it's out of warranty, you could either send it to our factory for repair or order just the replacement part and have it exchanged by a local service place.
Linsoul is our partner for replacement parts: https://www.linsoul.com/blogs/announcements/shanling-audio-repair-services-at-linsoul-audio
Audiophonics is a good and reliable dealer. They ship almost everywhere and are quick to restock items. If anything is missing on their site, just send them email.
actually I have emailed them before and they said they do not have replacement parts because they said you already have stopped production of that model. i emailed them again showing this screenshot, still they said they do not have any replacement parts
May 20, 2024 at 10:36 PM Post #2,447 of 2,512
We still have these parts in stock. But for batteries, you would have to buy directly from us, as they demand special form of shipment and can't be shipped to certain locations.
You can email us at info@shanling.com
Jun 5, 2024 at 8:28 PM Post #2,449 of 2,512
Anyone having issues with MQA playback in tidal? Mine is stuttering in every somg in that format either streamed or downloaded offline.
Yes, MQA playback from Tidal app is broken on M3X. We can only recommend to either use playback through UAPP or set Tidal to Hi-Fi quality for MQA files.
Jun 10, 2024 at 12:57 AM Post #2,455 of 2,512
Introducing Shanling M3X
Android Hi-Res Portable Player
M3X is our newest Android Hi-Res portable player, built on the same platform as our previous three Android models. But this time we are aiming at the more affordable part of the market, with a little bit less focus on the most demanding DAC chipsets and the most powerful amplifiers.
M3X was designed as a scaled down version of our flagship M8, to be a more practical and smaller player, with only 4.2-inch touch screen. Making it 25% smaller and lighter than our older M6 and M6 Pro players.
M3X is a first Hi-Res player to use the new ESS Sabre ES9219C DAC/AMP, a new generation of a very popular chip that was previously used in our M0, UP4 and other products. Using two of these chips, to offer a balanced 4.4mm output for better sound and more power. And also including full 16x MQA unfolding, for all fans of the Hi-Res music streaming.
M3X will stand out with its class leading battery life, offering up to 23 hours of playback on a single charge.
Availability at international markets - March 2021
Price - 339 USD / Euro
Specifications
System: Open Android 7.1, with AGLO
Screen: 4.2 inch, 1280 x 768
CPU: 8-Core Qualcomm Snapdragon 430
Memory: 2GB RAM + 32 GB ROM
Expendable memory: MicroSD card slot
DAC/AMP: 2x ESS Sabre ES9219C
Hi-Res Audio: Up to PCM 32/384 & DSD256
MQA Support: Full unfolding, 16X
Outputs: 3.5mm jack Single Ended & 4.4mm Balanced
Wi-Fi: 2.4G & 5G
Bluetooth transmitter: LDAC, LHDC, aptX HD, aptX, SBC
Bluetooth receiver: LDAC & SBC
USB: USB-C, with USB DAC and USB transport function
Battery: 3200 mAh
Battery life: Up to 23 hours (SE, single DAC) / 20 hours (SE, dual DAC) / 19 hours (Bal)
Dimensions: 109 x 72 x 15.9 mm
Weight: 168g
Output power: Up to 240mW @ 32Ohm (Bal)
Output impedance: < 1Ohm
Leather case sold separately
Will M3X get Android OS upgrade? Most of the apps have made Android 9 as their lowest supported version while we're stuck with Android 7 on M3X!
Jun 10, 2024 at 8:54 PM Post #2,456 of 2,512
Our software team has no plans for OS upgrade.
Jun 14, 2024 at 12:29 PM Post #2,457 of 2,512
Battery is done.
I bought my M3X just about 2.5 years ago - Feb '22.
Recently the battery life has been not great, and in the last week or two noticed I had to recharge it every time I wanted to use it. Now I get only about 30 minutes of life out of it, with no apps running and screen off. With screen on, you can watch the numbers tick down. A single reboot will drop the battery by about 50%. I factory reset it. No change. It's on firmware 1.7 - multiple attempts to install 1.75 failed.
Has anyone replaced the battery on an M3X, or it just time for a new DAP?
