From one day to the next, the dap loses 10% of its battery, being turned off, is this normal?
Shanling M3X Portable Player - Our smallest Android Player
pietro77
- Mar 8, 2015
I was told it is not normal. I'm waiting for battery replacement to check if it is problem with the battery. When yours dap is on, but not used it still loses 10% or more? My loses around 30-40% per 12 hours.From one day to the next, the dap loses 10% of its battery, being turned off, is this normal?
I can't tell, mine turns itself off due to inactivity after a few minutes. Where did you buy the battery?I was told it is not normal. I'm waiting for battery replacement to check if it is problem with the battery. When yours dap is on, but not used it still loses 10% or more? My loses around 30-40% per 12 hours.
pietro77
- Mar 8, 2015
You can change it in settings/general/scheduled power off and observe. I bought mine battery on aliexpress, but on previous page Shanling posted link to their partner where you can order battery, I might order from them also as for now tracking from aliexpress not moving at all, it might be long wait.I can't tell, mine turns itself off due to inactivity after a few minutes. Where did you buy the battery?
Thanks, I'll check and tell youYou can change it in settings/general/scheduled power off and observe. I bought mine battery on aliexpress, but on previous page Shanling posted link to their partner where you can order battery, I might order from them also as for now tracking from aliexpress not moving at all, it might be long wait.
Jotaro
Does anyone have the situation that player not charge, just say not charging?
Do you have the player on “Transfer Files” still? I don’t think it charges if that is on.
Jotaro
Yeah. I try that is hot and miss nowDo you have the player on “Transfer Files” still? I don’t think it charges if that is on.
Jotaro
What are the Poweramp app recommended settings. Shangling says that turn off oversampling but I am little confused. Thanks
Is this brand new unit or some years old?
Also, do you experience any other shortening of battery life, apart from the battery indicator showing this after startup?
Can you send us screenshot of this?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
The dap was bought 1 year ago. I have tried to reproduce what happened. When I have turned it off, in 24 hours, it has not lost battery charge this time. When I have left it on without using it, it loses 10% in the same 24 hours. I am thinking of doing a factory reset, how can I do it?¿Esta unidad es nueva o tiene algunos años?
Además, ¿experimenta algún otro acortamiento de la duración de la batería, aparte del indicador de batería que muestra esto después del inicio?
¿Puedes enviarnos una captura de pantalla de esto?
Hi Pietro, I have checked, mine loses 10%.I was told it is not normal. I'm waiting for battery replacement to check if it is problem with the battery. When yours dap is on, but not used it still loses 10% or more? My loses around 30-40% per 12 hours.
FlacFan
- Mar 10, 2015
10% enegy loss over 24 hours in idle mode - I consider that normal. Your cell phone will be in the same range.
You can actually control what idle mode allows to run. If you turn BT and wifi off you basically run 'airplane' mode and here you should see the least amount of power loss.
Cheers.
Cheers.
10% in 24 hours is actually quite alright for running Android device.The dap was bought 1 year ago. I have tried to reproduce what happened. When I have turned it off, in 24 hours, it has not lost battery charge this time. When I have left it on without using it, it loses 10% in the same 24 hours. I am thinking of doing a factory reset, how can I do it?
If you wish to do a factory reset, it's in system settings - Backup & Reset - Factory data reset
Ferdze
nope, it means your unit is dead in just 10 days without even using it. how old is it?From one day to the next, the dap loses 10% of its battery, being turned off, is this normal?
