Shanling M3X Portable Player - Our smallest Android Player
Oct 8, 2022 at 8:23 PM Post #2,087 of 2,444
Why the apple music setting always revert to internal storage after boot up, or is this coz of the app itself. It quite annoying tbh.
thanks
Our software team recommends using only internal memory for the offline data of streaming services. Some of the apps have issue recognizing cards inserted into M3X, so they revert to internal memory.
Oct 13, 2022 at 4:46 AM Post #2,089 of 2,444
i paired my m3x with my desktop computer via bluetooth and used the app "bluetooth audio reciever" to connect the two devices.
the m3x now shows up as microphone within the windows sound configuration. neat.
however, there is a mild inconvinience: no matter what i try the connecion quality seems limited to sbc.
both the computer and the m3x should be capable of using a higher quality connection type. i have tried variouis settings for connection quality on the m3x, but i have not found any way to do this configuration on my computer.
i have no idea what causes this isue as i am sure my computer used higher qualtiy codex in the past if i had set them in the connected device.
any idea if there is anything i can try to improve this?
Oct 13, 2022 at 4:59 AM Post #2,090 of 2,444
Does the bluetooth in your pc support codecs other than SBC? You know just because it is a pc doesn't mean it has everything already. If you are using a cheap bluetooth dongle, chances are there's no support for hi-res
Oct 13, 2022 at 5:15 AM Post #2,091 of 2,444
Receiver mode on M3X supports only LDAC and SBC, does your computer support LDAC?
Used Codec is set on the source (computer), there is no setting affecting this on M3X itself.
Oct 13, 2022 at 8:52 AM Post #2,092 of 2,444
Still no word on the Shanling M3 Ultra?
H7 was posted right away :grin:
https://weibo.com/2714034801/M9XLQpi1k
Oct 13, 2022 at 2:54 PM Post #2,094 of 2,444
my mainboard has a build inIntel Wi-Fi 6 AX200 card.
the only information intel was willing to share is:
In this case, we need to inform you that all Bluetooth codecs are managed by the operating system on Windows 10;... our strongest recommendation will be to get in touch with Microsoft...We will proceed to close this thread
i also found a lot conflicting information if or if not windows 10 supports ldac, but no solution or driver to make ldac work if it does not.
Oct 14, 2022 at 3:11 AM Post #2,095 of 2,444
Just buy external bluetooth adapter, modern pc/laptop doesn't have advanced codec unlike smartphone which has superior bluetoooth chip
Oct 15, 2022 at 1:48 AM Post #2,097 of 2,444
My laptop Asus G14 only support up to aptx, its weird why they don’t include aptx as most of them time our device is ldac or aptx, only apple aac only.
Thats why i still keep my qudelix 5k and can’t make M3X one for all device, on paper it looks good but the moment you nitpick it all sort of problem pop up, random restart while using it as usb dac for example, slow wifi that can’t even update itself via internet (download from drive takes below 10 minutes), unuseable bluetooth reciever on all but ldac, no all eq, an okay player, random “click”ing sound when used as usb transport, etc.
But still one of the best dap on its price (not the Limited one).
I suggest just use m3x as a dap to play music, any other just buy dongles or qudelix 5k for desktop and portable use.
Oct 18, 2022 at 5:21 PM Post #2,098 of 2,444
@Shanling
.com.shanling.MusicApp breaks saving of custom home app
i want to use the nova launcer on my m3x. sadly, the home app is not stored on the m3x, every time i reboot the system it will change to the default home3 launcher.
using adb to remove launcher3 did not fix this behaviour. instead of accepting nova launcher as my default saved home application, after removal of launcher3, the device would ask me after every restart if i wanted the nova launcher or the shanling music app as my default launcher (setting did not get stored).
i tried to grat the launcer more permissions but nothing worked.
nova launcher finally stuck as launcher after removal of com.shanling.MusicApp.
now, i did not use this application. still, it was nice if your software team could fix this. changin the launcher is a customisation option i simply expect from an android device. using the adb to hide pre installed packages is a barrier not everybody is willing to take; removal of the music app also is a step many would not want to take.
Oct 18, 2022 at 8:30 PM Post #2,099 of 2,444
@Shanling
This is a decision by the software team to not allow alternative launchers, as they conflict with the prime mode.
Oct 18, 2022 at 9:15 PM Post #2,100 of 2,444
@Shanling
just remove the stock launcher and shanling music app via adb using a pc. prime mode will be lost as it's just the shanling music player on foreground. you're better off with other music players
