Если карта 32gb тоже форматировать в ЕxFAT?
Standard for Head-Fi is to use English.
But otherwise, I format even our 16GB cards into exfat and they work flawlessly.
Sorry if this was answered previously... do I need to do anything on the M3s in order for it to use aptX when connecting to earphones? Do I just need to make sure that System Settings -> Bluetooth -> High Quality is turned on? How can I tell if aptX is actually being used?
My M3s is on v1.5 firmware and the IEMs I plan on using are Soundcore Liberty 2.
Thanks!
Yes, just turn on high quality in settings. And if you see A in status bar, it's connected over aptX, if S shows up, it's just SBC.
Whats the latest FW ver for these? the 3.5 on mine really is behaving weirdly, somtimes it come out completely imbalanced on one side, i plug off the jack and plug it in again and it changed to different side, againa nd its less prominent, but still leaning a tad to a side, then soemtimes nothing at all and completely fine.
it's super weird, as nothing really happened when i put it into LO mode, and i also tried doing the same with the 2.5 bal, plugging it off-on a couple times and it doesn't happen either... meaning it aint the amp, so now I'm stuck thinking there might ebs omething very weird going on with the 3.5mm female, like one fo the solder coming off and on randomly with movement or something... or its software thing. so thus I ask, where can i download the latest? clicking the download link on Shanling's page for M3s lead me nowhere
that link lead me to: http://jogm-taste.interserver.toplives.cn/download/55
i pick it from http://en.shanling.com/product/225
Seems link on product page is broken. You can find M3s downloads in Download section of our website http://en.shanling.com/download/55
For your problem, few things to try.
On software side, factory reset or downgrading/updating firmware, to rule out any software glitch.
On hardware side, clean out 3.5mm jack from any debris or take your M3s to some repair guy, who could check contacts inside.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
