FenceFurniture
I think it would be very useful if you produced a User Guide like that for the M3s - surely it can't be too hard to do?You can use your iPhone with M3s in this set up, but audio quality will be limited by the Bluetooth implementation on M3s, which allows only SBC codec in receiver mode.
Our new generation of players, M0 and M5s, supports more advanced codes. But with your iPhone you would still be stuck at AAC, in theory not using full potential of Tidal files.
For our new system, we prepared more detailed user manual, that will tell you little bit more about the items in system.
https://drive.google.com/open?id=1drykys2aLbbwccu8oxes0dcyvQDe-qOE
But if you want to learn more about basic terms used in modern audio, like what is gain and DSD, I can only recommend you to go on Google. Some of these terms has easy explanation, some of them can take articles.
I'm also wondering how well the M3s will work with the HiBy on my Xiaomi Mi 8 phone. I don't wish to stream Spotify or anything else, but I would like to be able to receive phone calls while listening to the DAP. (I use FLAC files.)
What would you suggest is a good amp to use with the M3s?
