Thanks @DBaldock9, this sounds good.
Have you maybe tried using it with an android device, too? Does it work with UAPP?
Hi guys, a question about using the M3S with external DAC/amps and battery life.
My M3s is new, barely a month old. When I use it with my ifi iDSD BL dac, the battery will drop to 3 bars from full within an hour usage. This is with the screen off. Without the DAC (with iems plugged into the M3s), battery stays at full after 1 hr usage. Does using an external DAC drain more battery from the player?
The DAC has it's own battery and is fully charged, it shouldn't be drawing power from the M3S.
Just to double check, have you installed the correct firmware (version b) on the iDSD and are you turning it on before connecting it to the M3s?
I've been using it for 2 hours straight with the iFi xDSD via USB C to USB A cable, 100 volume, playing Hi-Res music, and with Bluetooth on using HiBy Link. The battery icon hasn't changed at all yet and is still at full battery.Hi guys, a question about using the M3S with external DAC/amps and battery life.
I didn't even know the M3S supports digital out via the USB port. It doesn't say it does that in the product page, nor the user manual.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Just to check, do you always turn on the iFi before connecting the USB cable?
Also, what cable are you using? There might be some problem with pinout.
Yeah I guess I misread the product page. When I was looking before, I was looking for S/PDIF via USB C, which it doesn't support like the Cayin DAPs. It does support USB output though.It definitely does support digital out. My IFi LED changes color when I switch from DSD to 24bit and 16bit tracks on the M3S.
That Anker cable fits in the iDSD? I wasn't sure about the rounded corners so I opted to buy the Amazon Basics cable instead, and it seems to be working just fine with the xDSD.Yes, I always turn on the iFi first before connecting the M3S. Using Anker cable - https://www.amazon.com/gp/product/B01COOQIKU/ref=oh_aui_detailpage_o01_s02?ie=UTF8&psc=1
To answer my own question: it work with both windows and linux using an usbc to usbc cable. Liking it so farHi guys, sorry if I bother you with a couple of questions but I haven't been able to find a definitive answer:
1) Does it work as an external DAC on a PC using an usb-c to usb-c cable?
2) Does it work on linux using the setup as of 1? Does it work on linux at all?
Thanks and sorry again
I'm very happy that I can actually connect my phone to the Shanling via Bluetooth but I hear a very noticeable delay during playback, this also happens when trying to play games where it will be more obvious since you're clicking on menus with a sound feedback and it's obviously delayed.
