Shanling M3s - dual AK4490 DAC, 2.5 balanced out, aptX BT, HiBy link, USB out, FW 1.7
Jan 13, 2018 at 1:59 PM Post #1,429 of 2,219
Does it receive Aptx Bluetooth from my phone to the M3s?
Probably not, since there doesn't seem to be a single chip solution that receives and transmits Bluetooth aptX - so the DAPs use the transmitting chip, since they're focused on sending their music to headphones, speakers, etc.
Jan 13, 2018 at 2:01 PM Post #1,430 of 2,219
It's a shame. Because Deezer streaming is not possible than. Guess the only way is an Android DAP with wifi.
Bluetooth SBC sucks...
Jan 13, 2018 at 2:06 PM Post #1,431 of 2,219
It's not like aptx or aptx hd is completely lossless either, but progressively higher bitrate. You can try and see if it sounds all that different between using the m3s in dac mode playing from deezer (via pc or android phone if that's a supported feature) or bluetooth streaming.
Jan 13, 2018 at 2:21 PM Post #1,432 of 2,219
Not to dissuade you from getting an M3s (because I really like mine), but if you just want a good Bluetooth HD aptx Receiver / USB DAC / Amp, for driving your earbuds / earphones - take a look at the EarStudio (has single-ended (higher current) & balanced (higher voltage) outputs) - https://www.kickstarter.com/projects/323636065/earstudio-worlds-first-studio-quality-bluetooth-re
Jan 13, 2018 at 2:33 PM Post #1,433 of 2,219
I currently own the Cayin N3 which isn't capable either.
Testing it right now on my N3... Again.. Because on Android Nougat it wasn't working with usb audio. And guess what on Android Oreo it's working!!
And off course definitely way better than Bluetooth SBC. Shame I can't test APTX streaming. Heard it's a big improvement.
Jan 14, 2018 at 8:48 PM Post #1,434 of 2,219
Purchased my M3s during BF last year. Awesome player , pair with FLC8s, great sound stage and superb clarity, lots of energy and it's musical.
@Shanling , any chance you can incorpate "Repeat Folder" play mode in next firmware update please?
If you want to repeat folder, just change "play mode" into "repeat all" and turn off "folder skip".
As @DBaldock9 said, there is currently solution, at least to our knowledge, that would serve for aptX in both ways. We must face world, where portable players are small market, so making solutions for such a specific purpose is not interesting for components manufacturers.
Jan 17, 2018 at 2:03 AM Post #1,436 of 2,219
Shanling M3s with qdc Neptune, sweet combination, both build in Shenzhen.
Jan 20, 2018 at 11:26 AM Post #1,438 of 2,219
Please can anybody show me how to use Shanling M3s as DAC with iPhone ? Thanks in advance :) (Sorry for my bad English)
In the player controls, you would use Line-Out mode to On. Then in the main settings, have to pair to your iphone with Bluetooth. I don't think the usb-c will allow it since it would need mfi certification.
Jan 20, 2018 at 5:49 PM Post #1,439 of 2,219
Tips and FAQ
How does the digital filters change the sound?
In M3s we use AKM AK4490 DAC and AKM prepared this useful chart explaining the functions of different filters and their effect on sound:
Can the single ended and balanced output be used at the same time?
It is possible, but it can lead to overheating and damaging the player. So we don't recommend this.
My M3s is warmer when using balanced output. Is it normal?
Since balanced output uses double amount of audio components, it's normal for the player to get warmer compared to single ended output.
How can I go quickly through my music library?
For quick scrolling use the prev and next buttons on left side of the player.
I messed up something during Firmware update and my unit doesn't react now, any help?
Send PM to Shanling and we will provide you with tool that can fix most software problems.
How can I set up HiBy Link for my player?
Go to our HiBY link thread, where you will find all needed info.
What is file limit on M3s?
15 000 songs
Shanling M3s USB Driver
Tip: Press and hold the wheel while on now playing screen for quick access to settings and more options.
Jan 20, 2018 at 5:50 PM Post #1,440 of 2,219
Tips and FAQ
15 000 songs
