Shanling M1s - Compact Portable Player (Discontinued)
Jun 5, 2023 at 9:44 AM Post #616 of 1,049
Will you ever add a keyboard so you can search your music? I know the screen is small but maybe make it a full screen keyboard. It is so hard to find my music on it 🥲
Also importing my playlists still doesn't work. All the files have their file extensions after them and they don't play the music.
Jun 5, 2023 at 9:50 AM Post #617 of 1,049
Also importing my playlists still doesn't work. All the files have their file extensions after them and they don't play the music.are th
Do the names of the playlists show up in the playlist section?
Jun 5, 2023 at 10:02 AM Post #622 of 1,049
I use foobar. They need to make playlists easier. When I import music it worked but the album section were unknown when it’s playing. So I deleted the files from each playlist (not source delete) and added the same files back to each playlist because it keeps its name. Works fine that way.
Ah, thing is I need the files to work because many of my songs aren't in English so the alphabet sidebar is not very good for it. 😬
Jun 5, 2023 at 11:08 AM Post #624 of 1,049
Does the M1S have a similar sound signature to the bigger M3X?
Jun 5, 2023 at 8:17 PM Post #625 of 1,049
Accurate or not it helps guesstimate remaining hours before it runs out. I usually just play my music and turn off the screen.
Kind of depends on how inaccurate it is as to how useful to guesstimate. If Shanling could provide a ballpark figure on how inaccurate the meter is that would something at least. I know from my A55 once the low battery warning comes on I have about 4 hours of battery life left. I know that Hiby has a percentage indicator on their non-android DAP's but again not sure how accurate the percentages are.
Jun 6, 2023 at 1:32 AM Post #627 of 1,049
Not sure yet on search function.
For playlist, please send us PM, we can look into it. You can include a sample of your playlist.
Mine just went to a white screen and reset won’t fix this. Any ideas?
Please send us PM.
Jun 7, 2023 at 12:50 PM Post #628 of 1,049
Jun 8, 2023 at 10:59 AM Post #629 of 1,049
Ordered a M1S of Amazon uk on Tuesday and got it today. Works great! Much smaller than I thought based on pictures and videos.
Anyway to disable the auto text scrolling of folder names?
Also in the player view disable lyrics? I want the screen with all the file info as default.
Jun 8, 2023 at 11:59 AM Post #630 of 1,049
Unfortunately text scrolling can’t be disabled. As far as file info you can’t default. You have to swipe to left every time when u bail out of now playing screen.
