Ya I really like mine a lot..I love my M1s, perfect size for IEMs and insane sound quality, powerful small beast!
Not planning to replace it anytime soon.
Shanling M1s - Compact Portable Player (Discontinued)
- Thread starter Shanling
Shanling team... I've mentioned this before but DSD (.dsf) files ALL play with the first second or so cut off. Why?? Also, no gapless playback with DSD and no EQ. Can any of this be fixed? Otherwise... I love my M1S!
Shanling team... and add double tap for wakeup display, please. )
Not possible on our Mtouch devices, only on Android.Shanling team... and add double tap for wakeup display, please. )
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
threegr
I've noticed that gapless playback doesn't work after the last update. EQ or without it, it doesn't matter. Has anyone else noticed this?
Yes, same with mine. I've reverted to V2.6 and Gapless is working again.I've noticed that gapless playback doesn't work after the last update. EQ or without it, it doesn't matter. Has anyone else noticed this?
V2.0 brought additional optimization of Gapless, it should now work without issues. Maybe can you try factory reset?I've noticed that gapless playback doesn't work after the last update. EQ or without it, it doesn't matter. Has anyone else noticed this?
threegr
I would hate to lose all my settings, especially EQ settingsV2.0 brought additional optimization of Gapless, it should now work without issues. Maybe can you try factory reset?
We don't see any issue with gapless on V2.0, so we can't say what will or not fix issue we can't replicate.I would hate to lose all my settings, especially EQ settingsAre you sure that it would fix the issue?
I re-installed V2.8 and did a factory reset. Turning the Gapless setting back on worked!
Dvl Kubo
- Oct 5, 2016
I really like this player size is honestly perfect hope you guys something similar as i felt the m1 plus is a bit big I ended up buying both colors and one extra black as a spare
jjb3
- Nov 4, 2010
I have the M1S. Recently got the Hiby M300. Highly recommend.
I really like the sound, for a tiny device it has great rich sound that feels very high end, even though technically it's not, but the tuning is done so well, it sounds just great
Dvl Kubo
- Oct 5, 2016
I almost got that but due to no balance output i said umm nvmI have the M1S. Recently got the Hiby M300. Highly recommend.
