Shanling M1s - Compact Portable Player (Discontinued)
Aug 31, 2023 at 12:31 PM Post #721 of 1,051
Another problem. In "usb storage" mode, the computer does not see the memory card. The card works fine in the device. I can browse files and listen to music. I see the device in device manager as Linux File-Stor Gadget USB Device. But no drive is visible in the system. I'm using a Samsung pro plus 128GB card. The file system is exFat. When I insert the PNY Pro Elite 64GB with exFAT the system recognizes the card and the drive appears in the system. I tested on windows 11 and 10.
Sep 2, 2023 at 6:34 AM Post #722 of 1,051
Hello.
@Shanling Could you tell please, are there any plans to improve playlists management? I'm trying to use the m1s player as a portable DAC, and it would be great to have the ability to manage playlists on the go without connecting it to the PC to create and edit playlists. The most important features imo would be assign custom names to playlists and rearrange songs in created playlists. Even being able to do this from the Eddict Player would be great.
Thank you very much.
Sep 4, 2023 at 9:10 PM Post #723 of 1,051
So, to be clear, the issue is just with one card, while the other one shows correctly? Does this card work without issues with standard card readers?
Hello.
Unlikely to be implemented.
Sep 5, 2023 at 3:17 AM Post #724 of 1,051
The card is new, taken out of the packaging. Works on two card readers. And on any other device. Works normally in m1s too. Playing songs, scanning, reading works. It does not work only when the cable is connected in windows. I would buy a new sd card but I am not sure if it will work since there is such a problem with the new card.
Sep 5, 2023 at 3:33 AM Post #725 of 1,051
Few times I saw player having issue with reading the card and it was due to card being fake. Otherwise we are not aware of any other reports of such case, where the M1s would refuse to show the card when connected to computer. As is shown with your other card working fine.
Which device you used to format the card?
Sep 5, 2023 at 3:43 AM Post #726 of 1,051
I formatted with a Toocki USB 3.0 card reader to exFat. I also formatted in the Xduoo x3 II player. In both cases, the card works the same. It works on the device, not on the cable. It is also not visible in any way with m1s in partition management programs.
Edit. After disconnecting the cable, the card stops working in the m1s. After reboot it works fine. Until the USB cable is plugged in.
Sep 5, 2023 at 8:23 PM Post #727 of 1,051
Curious case, if you could get a third card to compare, it would be helpful to know how it behaves.
Sep 6, 2023 at 3:22 AM Post #728 of 1,051
I used some old alfawize 32 GB. Works well. A bit small and slow for me. I ordered Kingston Canvas select plus 128GB from Amazon yesterday. I'll know tomorrow if it works. I hope it works because it's a bit random. The Samsung card was also from the official Amazon distribution and works normally in all devices I have. Just not in m1s.
Sep 6, 2023 at 3:34 AM Post #729 of 1,051
I would personally never recommend buying cards on Amazon. Always only from dedicated electronics stores or manufacturer e-shops. Amazon had issues with fake cards and I don't trust them enough to be sure they solved it.
Sep 10, 2023 at 11:19 PM Post #730 of 1,051
I have bought both latest Hiby R3 II and Shanling M1S ( For Similar Price Range and Size ).
My first impression is that it will be perfect if
Hiby's Design ( Easy for holding and control )
Shanling's Tuning ( Although not so warm but I like it )
Ingenic X2000 ( For smoother control )
And better to have higher resolution
I look forward to seeing more compact DAPs in the future.
Sep 10, 2023 at 11:24 PM Post #731 of 1,051
Which one you like better? And why?
Sep 11, 2023 at 4:49 AM Post #732 of 1,051
I wasn't aware that the Hiby R3 II had been released yet but from your criteria it looks like a win for Shanling. Not sure why Hiby would release a new device using the old x1000. Very odd decision.
Sep 11, 2023 at 4:56 AM Post #733 of 1,051
Yes.
With X1000 and Low Resolution, the experience on Hiby is not that comfortable.
Although the shape is user-friendly and the MSEB is quite interesting.
