Shanling M1: An iPod Nano Competitor / DAP || USB DAC || USB Transport || Bluetooth 4.0 + aptX || DSD
Jun 28, 2017 at 3:12 PM Post #2,731 of 3,480
@Shanling. Please speak to your engineers and verify that the unit "natively" plays DSD. I was under the distinct impression, from Shanling, that the unit does NOT natively play DSD. Instead, it does indeed convert DSD on the fly to PCM and plays that. Some early marketing videos had that fact incorrect and stated native DSD and that error was confirmed by Shanling. However, it can act as a DSD transport for the Chord Mojo, etc.
Your most recent post could be interpreted as stating that the unit natively plays DSD and I am fairly confident that is NOT correct. In my view, there is a difference between decoding to PCM on the fly vs native DSD playback.
Well, it was my mistake and missunderstanding communication with my colleagues. M1 support DSD only over USB out, when playing directly, it converts DSD to PCM.
Truly sorry for all this confusion.
Thanks Shanling, just ordered the awesome OTG cable. Hope to receive my M1 next week to pair with my Mojo.
Great product - was a big gap in the market. Not even thinking about the Chord Poly now and look to save myself +$800USD net.
Now only add piece of 3M dual lock and all is set :wink:
Yes, it will transmit in aptX, just not receive.
Correct, unfortunately current solutions are limited in this. Seems like nobody think of device, where both way AptX would be useful...
Jun 28, 2017 at 3:46 PM Post #2,732 of 3,480
Personally if I had a Mojo this is the route I'd go:
Elegant and no sticking anything unto my expensive devices.
Yeah, I figured. The chip maker just didn't think it through. You're mainly using BT to stream audio, so you think aptX both ways would be a no the obvious choice.
Jun 28, 2017 at 6:01 PM Post #2,733 of 3,480
Hi - I tried searching but couldn't find an answer . . . when viewing my music collection by artist . . . I am a seeing a (seemingly) random collection of songs grouped together as 'unknown album' under some artists.
All of the albums under the same artist are correctly displayed but I also have this 'unknown album' item. Most artists groupings are OK . . . but some have this issue.
What is distinct about these random 'unknown album' groupings is that they are in fact the track titles from the metadata (and not the filename that is used in the correct album groupings).
My track file naming is completely consistent across my collection and the metadata is pristine (even if I do say so myself).
Anyone experiencing the same issues? Is this a known issue?
Otherwise loving my M1 . . . and yes, it does output a DSD stream (as confirmed by the white LED on the Chord Mojo)
Thanks for any help
Jun 29, 2017 at 3:39 AM Post #2,734 of 3,480
Introducing Shanling L2 USB cable
USB transport is one of the most popular features of M1 player, easily turning it into amazing music source for wide range of DACs. But search for appropriate USB cable can be tiring, so we decided to develop our own!
Build by hand from top quality materials, Furukawa 6N silver plated copper wires from Japan. Highly practical thanks to angled connectors (USB C to Micro USB). And working flawlessly with Shanling players and wide range of DACs.
Available from 23.6.2017 for just 25 USD
Ordered :)
Jun 29, 2017 at 2:45 PM Post #2,735 of 3,480
Thanks for any help
Tags are somehow messy. I would recommend, try to take one of these problematic albums, erase all tags and tag freshly, to see if it have any effect.
Jul 1, 2017 at 7:43 AM Post #2,739 of 3,480
can i use this as an usb otg bt aptx transmitter with my smartphone? my smartphone does not support aptx, so i want to use it as a streaming source, connect the shanling by usb to just get the digital stream and transmit it with aptx to my aptx headphones.
will that work?
Jul 1, 2017 at 1:00 PM Post #2,742 of 3,480
okay, i want to ask quick question , does the m1 support cue?? i want to rip some cd and im too lazy to split it so i think cue is the shortcut , i wanna ask this before i do it
Yes, it supports cue
will that work?
Unfotunately, this combination will not work.
Bought the M1 as an early self-birthday present, and I love it! Great sound (standalone) and awesome portability. Really enjoying it.
Jul 1, 2017 at 7:07 PM Post #2,743 of 3,480
Check the tags extended fields.
Hi - so I discovered the issue. I had included the cue sheets (*.cue) in the folder.
Removing the cue sheets solved the 'Unknown Album' issue.
