Make that every few seconds. Infuriating!
I’ll just use it as a stand-alone DAP for now
On HD files, it seems to cut out every few minutes.
I’ll try connecting a dummy load to the headphone output...
order placed. when it arrives i will post a comparison with lg v20. im not an expert though i will just say if it sounds good or bad compared to v20.
Do you happen to know when will they start shipping?
About the same as the V20, slight edge for the V30 in detail retrieval but could be psychoacoustics on my part .
Yes, FLAC (from HDTracks).
My SD card is a 200GB SanDisk.
your SD is formatted as FAT32 or exFAT? that could be a issue, it has to be FAT32Yes, FLAC (from HDTracks).
Great!Titanium and black are in and shipping
that's not common, do you have firmare 1.5 also? maybe it's a defective unit, hope it's not. mine had some issues of freezing in boot screen and it was for the exFAT formatted card, and some trouble with hissing and it was for the firmware 1.0Mine is in FAT32 and I too have this issue.
Also, wipe clean the display, just to make sure it's not covered with too many fingerprints or some residue.
Thanks @twister6, cleaning the screen with a microfibre cloth and a drop of distilled water did it for me.
thanks.About the same as the V20, slight edge for the V30 in detail retrieval but could be psychoacoustics on my part .
