keenids
Anyway, I also have a serious question. I read the discussion about problems playing gapless.
I have a problem with the end of sound files, that might be related. I have a lot of sound files (some of which are self-made) that do not have silence after the ending of the sound. The sound goes on until the very end of the file. (This is exactly the same as a track from a gapless album)
But the M0 does not play the entire file. In the last second of the sound, it makes a fade-out. The end of the sound is missing. In case of spoken word, it is very clear: the last word is not there.
I tried solving it by turning GAPLESS to ON. This works, but only 1 time. One file is played till the very end, and the next one is faded out again...
I tested it with a very short (10 seconds) spoken word file and PLAY MODE on REPEAT TRACK.
With GAPLESS OFF, the end of the sound is faded out every time. I am not sure but the missing part is 1 second, maybe 0.5 second.
If I turn GAPLESS to ON during playback, the next ending is played correctly, and I can hear the last word. But after that, the end is faded out again, even more than before.
I have 2 M0's and they both do it. Both have firmware 3.0 installed. The sound files are mp3.
Question 1: The M0 can play the audio correctly. But why can I only make it do so by switching GAPLESS ON during playback? And why does it stop playing correctly after that?
Question 2: Why is the M0 fading the sound in the first place? I really cannot think of any situation where I would want that. I want to hear all the audio in the file. Is there a technical problem?
Question 3: Is it possible to have a playback mode RAW, where all audio files are played exactly as they are, and complete? (I would prefer that, even if there would be gaps)
I have written to Shanling about this, but I got no reply. That is why I try here. Keep up the good work, any reply is appreciated.
