I think if Shanling pairs this ESS chip with a better amp on their next DAP like say the next version of the M2S or M3S I would buy it in a heartbeat. Still might spring for the M5S if it ever gets released in Canada.
ESS used in M0 is SoC, all in one unit.
Firstly, not sure if anybody knows how difficult would it be to work in this chip, change it's connections, software, etc.
Secondly, why to do that, when you can simply decide to use dedicated DAC chip if you are already putting there dedicated amp circuit, making the device bigger no matter what.
Anyone knows if it's possible to use m0 as a source for Android device via USB (phone or car media). maybe there's any Android app that can do so ?
Well, you can use M0 as USB DAC with Android phone. Not sure how would you like to use M0 as source for Android device? You can connect it in Transfer mode and view files on mSD card.
Just to chime in, i LOVE my m0. Bought it at CanJam London and have used it almost daily ever since. My main use is as a bt receiver for my iPhone (a necessary evil if i want the luxury of sitting with a phone in my pocket). The addition of controls in bt rx mode was huge for me. Big thank you. Running on aac, the m0 is a noticeable upgrade to not only my previous bt receiver but the hp jack on my SE. Kudos Shanling
However, there are little niggles and gripes that stop it from being as perfect as it can be.
First is the latency. Both in bt and usb modes. If i try to watch any kind of video on either pc or phone, the entire experience becomes unnecessarily frustrating. It is this blemish that stops this thing from being a part of the headphone itself.
Second is the eq but that's been mentioned umpteen times here already so i won't... Or did i?
Third is the sd slot cover. Admittedly, this is not pertinent to the functioning of the device but it annoys me every time i encounter it. Why is it there? Is it waterproof or something? It's so hard to pry open and I'm scared I'm going to tear the rubber gasket every time i dig my nail under it. It takes a good few attempts to open it too. And once you're done with the sd flap, it doesn't sit very well or flush either. Maybe i just have a janky Sd slot cover but nevertheless it's super annoying. I have multiple sd cards but i hate swapping cards on this DAP specifically because of this reason.
Next one is hardware so hopefully we can see it in the next iteration of the m0. The mic. How complete of a device would this be if it had a little hole at the top that served as a mic? Then i would have an uncompromising and complete experience with this thing. The M0 would become the 'it girl' of the audio and mobile world simultaneously and we'll drive off into the sunset together...
What? Back to the topic at hand, please
For the app, would it be possible to add the option for audible notifications from phone to m0? Vibrate is sometimes hard to notice while walking. I use the m0 mostly while I'm out and about. And the app can't come soon enough in my opinion. Love the size of the chassis, not so much the size of the screen. I know u can't have one without the other so... App please?
BT delay: You write you are using AAC, which has it's own delay caused by technology and no device on market can change that. Needs to be fixed by your phone, sometimes it can be hidden in some advanced setting or most video apps have setting for audio delay, exactly for this reason.
With USB delay, working on it.
I was testing early version of new EQ system recently, its sound is promising, so hopefully it will be in M5s and soon after that in M0.
Card cover, some people like it, some don't. Wast majority of users puts card into their player and takes it away once in a while, so for that we made cover that fits securely and doesn't flap around that randomly. If you think yours doesn't fit properly, you can try to play little bit with the o-ring, to make it fit more flush.
M0 is DAP first, so no plans to include Mic or functions to control phone calls. For that we will have UP2 with all functions of BT receiver.
Regarding phone notifications, M0 in that way acts as any other BT receiver or headphones. if you want notifications, turn on the volume on your phone.
Yes, that would be excellent, many want it, no Shanling plays Streaming? I liked the sound and I look for something with streaming but I can not find it? Which Sangling model is recommended? Even without streaming, M2? M3? Greetings and thanks!!
Streaming is always question of the system, developing system support for streaming apps takes time and simply using Android brings many other problems.
We believe our solution with using your phone and connecting over BT (or Wifi on M5s), is decent temporary way to get streaming on Shanling players, until better solution is finished.
Just curious if I could connect my Chromebook to my Shanling M0 via bluetooth and use it as a DAC to listen to movies / music from my couch...
M0 can works as BT receiver with pretty much all devices sending BT, so it's all about settings and possibilities on your Chromebook
I have a 3 albums from one artist that prompts "No File Found" when I click on the albums, but I can still see a list of all songs.Tried recopying the files to M0 and still has this issue. Only MP3 files in the folder. Has anyone experienced this before?
Send me one file in PM to check out, easiest way how to solve such problem.
Hopefully Frankie from @Shanling is listening (and remembers it was promised as a FW update at some point)...
Frankie - we're talking audiobook and podcast playback support. Nothing exotic - audible is "nice to have" but not mandatory, as many (most ?) people use plain MP3 format for audiobooks and podcasts...
Yeah, listening. Repeating posts on same topic will unfortunately not speed up our limited software team.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
