Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
Sep 29, 2018 at 3:57 AM Post #3,293 of 6,413
I don't know what's going on with my M0. I have it on auto-standby, but the battery drains pretty quick leaving it on standby. Anybody else having the same issue?
Do you have Bluetooth turned on? Did you change any of the default power saving options in the settings?
Sep 29, 2018 at 2:05 PM Post #3,296 of 6,413
I think that was the problem, I kept the bluetooth on. What can you do with default power saving options? Didn't notice that one.
I just mean things like Screen Off Timer, Auto Standby, Auto-Shutdown, Sleep Timer etc.
Sep 29, 2018 at 5:22 PM Post #3,297 of 6,413
One minor thing but the DAP doesn't always update - it sometimes get stuck at a few hundred or like today, 5,000ish.
I do have a lot of tracks - 128Gb worth, don't mind it taking a while to update, but annoying when I have to do it a few times, or I think it's done it, then the same tracks come around and I realise that it's only indexed a few tracks!
Otherwise, after a month or two of use, it's great.
Sep 29, 2018 at 9:12 PM Post #3,300 of 6,413
I;'m running 200 GB card, we even have loaded 400 GB card and they are running fine. How many song do you have exactly?
Also the player can't handle some special symbols, so µ-Ziq becomes 'Unknown'.
Becomes "Unknown" in which part of player? During browsing with tags or on now playing screen?
