Hi. Thanks for replying.
Please could you double check this statement, and maybe get your engineers to compare the output with android UAPP.
I really don't think the output is bit perfect as it sounds noticeably worse than when using UAPP in bit perfect mode. It's also worth noting that UAPP sounds slightly worse when not in bit perfect mode and a DAC connected to an Android phone sounds worse still if you use a different media player other than UAPP entirely.
In bit perfect mode UAPP bypasses the EQ entirely. This is similar to the 'Source Direct' or 'Bypass' switch you might find on an amplifier. These switches result in a sound quality improvement because the EQ circuitry is removed from the signal path.
When using the m0 the EQ settings are still active, implying that the data is going through EQ software. - whether or not you set it to OFF or not does not change this.
This is what the author of UAPP said about bit perfect mode:
'Without the bit-perfect option enabled, all audio that is read from the file is converted to 32-bit floating point and then converted to the appropriate 16/24/32 bit integer format when sending to the DAC (after optional processing that you chose like EQ, balance,upsampling). This leads to an error for about 20 or so out of 16.7 million values that are 1 bit 'off'.'
It would great if you could get the best sound quality possible out of the m0 as I'm sure many potential owners would be connecting it to external DACs.
Thanks.
First question, can you tell me, what cable are you using with M0? On previous models, we had some people using random cheap cables from Ebay, which resulted in less than ideal sound. I remember one case, where such cable made Mojo into super bass heavy device. Changing to Shanling L2 cable fixed it.
Secondly, M0 is not running Android, so there are no errors of system that UAPP is trying to fix.
Thirdly, EQ setting is not "still active", it only activates when you enable EQ.
Also, now going more into audiophile side of thing, different transports can sound differently. But on that note, I don't think we were getting any reports of M0 sounding subpar and we have a lot of people using it with different DACs.
I only have my Apple Airpods, I tried with them and the m0 showed AAC on the top bar. That's so weird. So, do you think this is something Sony should be aware of? Are there any people using Sony's bluetooth speakers with LDAC? Can you guys see the LDAC logo on the top bar when you connected? Also what is the difference between LDAC-Connect(Auto) and LDAC-HQ? I want to get the best audio quality possible!
So earpods works fine and just your SOny speaker is misbehaving?
Can you tell us, which speakers exactly are you using? There are other users with M0 and Sony speakers and seems to be doing just fine.
Can you charge M0 while also using it as Bluetooth dac?
No, charging only in usb mode (already wrote in this thread).
When using M0 as Bluetooth receiver, of course you can charge it with standard USB charger.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
