qafro
- Jul 29, 2014
How does M0 sound like connecting with Hugo2 DAC?
My unit behaves erratically sometimes - spontaneous decreases of volume to zero or very low level, jumps to the beginning/middle/end of tracks, skipping or rewind to the start of tracks, spontaneous additions of tracks to favourites (even if I tried to do this myself it can be challenging pressing the heart icon due to the tiny screen), etc.
Wonder what could be causing this, it can be quite annoying at times. My double-tap of the volume wheel is set to "pause", I don't think I am touching any controls when the above issues happen, and the screen is also turned off. Could it be because of the integrated remote control on the earphones I use, or interference with my iPhone (although bluetooth is off)? Or could interface buttons be somehow pressed on the screen when it is turned off?
... added the next one as a Favourite and changed the play mode from List All to Shuffle. ...
My m0 arrived this morning - it's a nice looking unit and easy to use!
I have noticed however that when using it as a usb transport into my Chord Mojo is doesn't sound quite as good as when i use UAPP in bit perfect mode from my android phone. There is a definite lack of spaciousness/clarity noticeable, particularly on hires albums when using the m0. It is really obvious when listening to the intro of Halo on my 48-24 copy of Depeche Mode - Violator.
Why would this be? It Is there a bit perfect mode i am missing causing the m0 to do some additional processing?
EDIT: I've just noticed that the EQ settings still take effect when using the usb output. This would imply that the data is being processed somehow and that it is not a bitperfect output...
hi @Shanling , I reset my speaker and removed all the previous pairings but still no luck. My m0 doesn't show which codec it uses when connected (apart from the traditional bluetooth icon).
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Aha! I thought I was seeing things. I have had my play mode changed to shuffle several times too but thought it was me being clumsy and perhaps touching something without noticing.
According to our engineers, M0's output is bitperfect and there is no processing.
Of course when you enable EQ, it's something else and of course it changes sound, as would any software on your phone or computer.
Can you try with any other BT device?
I only have my Apple Airpods, I tried with them and the m0 showed AAC on the top bar. That's so weird. So, do you think this is something Sony should be aware of? Are there any people using Sony's bluetooth speakers with LDAC? Can you guys see the LDAC logo on the top bar when you connected? Also what is the difference between LDAC-Connect(Auto) and LDAC-HQ? I want to get the best audio quality possible!
Im using wh-1000xm2 and it always shows LDAC at the top right corner when paired. Here's the speed of most bt codecs LDAC HQ - 990kbps. LDAC normal - 660kbps AptX HD - 576kbps AptX - 352kbps. LDAC Connection - 330kbps.I only have my Apple Airpods, I tried with them and the m0 showed AAC on the top bar. That's so weird. So, do you think this is something Sony should be aware of? Are there any people using Sony's bluetooth speakers with LDAC? Can you guys see the LDAC logo on the top bar when you connected? Also what is the difference between LDAC-Connect(Auto) and LDAC-HQ? I want to get the best audio quality possible!
No, charging only in usb mode (already wrote in this thread).Can you charge M0 while also using it as Bluetooth dac?
