Remiam7
As far as useing the MO on a watch band, it can be done with one of the watch bands for the 6G iPod Nano that can be found on Amazon.
People aren't satisfied with the clip because of its design, it because it's a clip. People want a clip, but they want a more secure design. And a simpler more secure design would function just fine on the wrist with a strap that allowed it to clip on.
No(t yet)
Not yet implemented.
Shanling M0 support hebrew ?
Is there any way to get the clip to be stiffer?
I was wondering if it would help to drill small holes on either side of the clip and run a rubber band or something through it to provide more clamp on the clip.
Did not try it yet as I fear the M0 might not click into the clip properly anymore then.
Running a rubber band over the screen will most likely hurt the touchscreen functionality.
@Shanling - Received my m0 today. Sadly it seems to have a touchscreen issue out of the box.
Random scrolling and clicking.
Video Link -
Purchased from AliExpress.
Looks like it needs an exorcism I take it you have tried soft and hard resets. That’s why I try to buy from amazon for easy returns. Although Ali is pretty good to deal with.
Why not translate the menu text to Hebrew then send that to Shanling. May speed it up
