Sun, sea & fun - perfect environment for M0 Pro & FA E3000
Yes. Bluetooth on M0 is gapless. I don't recall owning any devices that aren't gapless over BT.Last time: Can bluetooth connection play gapless? I'm having problems with my iFi Go Pod setup. Will try my B&O bluetooth headphones later today...
What are these IEMs?Hah! It’s alive! The reset did bring it back but what was that about? I never had this issue with the OG M0
634ears LOAK TWhat are these IEMs?
That's one drawback you'll notice with M0 specially when you have not used the original M0. I've come to learn to live with it's wheel behavior as the DAP's pros heavily outweighs it. Setting volume default/limit help a bit and because I know how the wheel behaves I can just thumb turn it in one or two up/down motion and get to as close to my desired volume level. Yeah it kinda suck and could be better.Even with the latest firmware the volume on my M0 Pro still doesn't work reliability. Crap.
Being a small Chinese company it would take a miracle to get them to admit a fault and recall them, or even issue a firmware patch for the problem. None of that makes them any money and money is all they are about. Strictly short term thinking. Cheat people and run.That's one drawback you'll notice with M0 specially when you have not used the original M0. I've come to learn to live with it's wheel behavior as the DAP's pros heavily outweighs it. Setting volume default/limit help a bit and because I know how the wheel behaves I can just thumb turn it in one or two up/down motion and get to as close to my desired volume level. Yeah it kinda suck and could be better.
As we told you before on June 13th, please contact your seller for warranty. Hardware defects can happen on the units, that's why there is warranty. There is nothing we can do about that with a software update.The volume wheel works as a volume control rarely if at all. Nothing helps. As said changing the Max Volume setting helps but only a bit.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Sorry to hear. My volume wheel has never ever failed. I've figured out hapless bluetooth is an iFi Go Pod problem, more than likely.The volume wheel works as a volume control rarely if at all. Nothing helps. As said changing the Max Volume setting helps but only a bit.
You made the unit but what it does isn't your fault? How much MONEY would you want to fix or replace the defective unit?As we told you before on June 13th, please contact your seller for warranty. Hardware defects can happen on the units, that's why there is warranty. There is nothing we can do about that with a software update.
Who did you buy it from? Since you have a warranty claim, contact the seller and arrange for a replacement. Stuff happens.You made the unit but what it does isn't your fault? How much MONEY would you want to fix or replace the defective unit?
