Shanling ET3 - Dedicated Digital CD Transport, With USB Drive and Wi-Fi Support
Jan 28, 2025 at 11:45 AM Post #1,127 of 1,473
But why can't @Shanling make the ET3 Roon ready?
Is it a matter of $$$ ?
Before they were bought by Harmon, manufacturers had to submit their devices to Roon for evaluation and approval. It wasn't necessarily about money. This was/is not a quick process.
Post Harmon, I don't know what changed if anything.
Maybe Shanling can tell us where they are in the process.
Jan 28, 2025 at 12:23 PM Post #1,130 of 1,473
Feb 2, 2025 at 12:48 PM Post #1,131 of 1,473
While we are waiting for Shanling's return, I was looking at the manual for the newly introduced SACD player, which has user configurable settings for 10 different I2S pin configurations. I wonder if the same could be done to the ET-3 I2s output via a firmware update, but don't know enough about the chip inside the device to determine if that is even possible. Anybody?
Feb 2, 2025 at 12:54 PM Post #1,132 of 1,473
Unlikely. Otherwise they already implemented it.
Feb 3, 2025 at 12:54 PM Post #1,134 of 1,473
I have question to @Shanling . When I play DSD thought coaxial cable it converts DSD to PCM. The sound quality of this conversion is good.
But why does it swap right and left channels?
Is it possible to fix it by firmware?
Feb 7, 2025 at 3:54 PM Post #1,135 of 1,473
Alrighty, my C.E.C. came back, and I just installed it. There was no "issue" other than the belt taking a form, given how little I use it. (It's a relatively new belt). I'm running it now to see if it glitches. The Shanling is on too, and I can easily switch between them via remote on the line stage. I also started building an I2S cable- what painstaking work, and ordered one today from Ali-baba.
Feb 7, 2025 at 3:58 PM Post #1,136 of 1,473
So.. what's the verdict?
Feb 7, 2025 at 4:00 PM Post #1,137 of 1,473
Can you say that the C.E.C. have a superior sound quality to the ET-3 ?
Feb 7, 2025 at 4:05 PM Post #1,139 of 1,473
So.. what's the judict ?
To make a meaningful comparison, I think I need to run in the Shanling a little more, and right now, I'm focused on making sure the CEC doesn't glitch- the US distributor ran it for 48 hours without a problem.
Then, what, two of the same CD/same mastering, etc. running simultaneously? I don't know if there are gain differences among DAC outputs, I guess I could use AES/EBU and pull cable from one to the other player using the same DAC with the line stage muted. Any suggestions? I do shoot-outs frequently on LP, and adjust for gain differences using meters to ensure I'm not misled by the "hotter" cut.
@Brummle wrote: "Does the C.E.C work as a streamer also?"
No, straight Redbook transport. Period.
