Shanling EC3 - Compact CD Player for your desk and small Hi-Fi rigs
Feb 3, 2023 at 9:26 PM Post #62 of 80
Perhaps he meant will the CD Player work with a computer by being the playback device that a computer can "rip" the music from to its hard disc drive?
ORT
Well, EC3 has optical, coaxial and RCA output, if you want to run it into some digital input on computer or ADC, then yes, you can sort of use it this way.
But EC3 doesn't work as CD ripper.
Feb 3, 2023 at 10:12 PM Post #63 of 80
One would need a simple optical to USB adapter so that the output of the CD player to the input of a computer, correct?
ORT
Oct 18, 2023 at 9:37 PM Post #64 of 80
Feb 12, 2024 at 10:46 AM Post #65 of 80
Hello,
To Shanling contact :
When I received the EC3 in January, I was really happy about the form factor, the top loading, the embedded functions and both the simplicity of this player.
The addition of AptX and AptX HD last October is really nice, even if LDAC works perfectly. Thanks for this nice update !
One thing to highlight is the ease of use of BT connection; once paired the EC3 connects really quickly and with no hassle every single time, which is not the case with every BT device I use...
But I expected to be able to connect from time to time BT capable headphones, using the EC3 as a source, and this is obviousely not the case. Would it be possible to use the BT chip as a transmitter, thus allowing to use this CD player together with BT headphones ?
(I saw Ampak AP6256 is capable of Rx/Tx and even WiFi !)
Another nice feature is the abilty to play tons of different file formats from a USB disk/stick or an SDcard. But it is mandatory to use Eddict Player, which needs multiple steps to get it going (go into configuration, set BT to SyncLink, go back to USB source, open Eddict player on the smartphone, set client mode, scan music, then play...).
As the interface is quite minimalistic but still has a graphical UI like some entry-level players, and uses a Ingenic x2000 processor, could it be possible to have a embedded player in order to navigate the files ?
Best,
Florian.
Feb 12, 2024 at 1:37 PM Post #66 of 80
Hello,
Best,
Florian.
Thank you!
ORT
Feb 12, 2024 at 1:44 PM Post #67 of 80
Hello,
Best,
Florian.
IMHO, Shanling really hit it out of the park with its EC3. The same is true of the company's ET3 dedicated transport. 👍
Feb 13, 2024 at 5:13 AM Post #68 of 80
Sorry, but my english is not good enough to understand this statement; does it mean the EC3 and ET3 are really good devices in your opinion ?
(out of the park could mean they failed, for me, but I can guess the meaning can be positive also; if you can explain ?)
For which reasons it is true, in particular ?
Thanks for the input, as well as for OldRoadTod !
Feb 13, 2024 at 7:26 AM Post #69 of 80
Yes, my statement means that both products are an excellent value for the money. 👍
Feb 27, 2024 at 8:42 PM Post #70 of 80
Unfortunately not possible to use the EC3 as source for bluetooth headphones.
We suggested to software team to add a simpler user interface for file browsing right on the units for EC3/ET3/EH3, but so far they took no steps in this direction.
Jun 3, 2024 at 11:48 AM Post #71 of 80
So I recently bought a brand new EC3 and it's great except... it basically won't play CDs properly. The CD seems to wobble inside the player and I get read errors about 98% of the time. And even when one did play, the wobbling noise of the CD from the unit was very loud. I have played with the top mount piece repeatedly, checked for loose parts inside the main unit, updated software, tried a factory reset, etc.
Have reached out to Shanling's customer service e-mail twice and haven't heard back. Original dealer also seems to be at a loss as to what the problem is. Major bummer so far.
I'm posting here to A. ask Shangling if they know what the deal is and B. see if anyone else with a top-loading Shanling has had a problem like this. I had a Rega Planet 2000 for many years and never experienced a single problem. Expected the same from this player, especially since it was bought new in the year 2024.
Here's a video for anyone who's interested...
https://photos.app.goo.gl/a5LKDWUurfbJ32NF9
Jun 3, 2024 at 12:08 PM Post #72 of 80
Sounds like you've had this problem from early on. IMHO I'd call Shanling and ask for a replacement.
Best of luck. 👍
Jun 3, 2024 at 9:27 PM Post #73 of 80
Sorry to hear about this.
Most likely issue on the CD Drive, we would recommend contacting your seller for warranty repair/replacement.
And can you please send me PM with your email? Will check why our colleagues haven't responded to your emails.
Nov 18, 2024 at 3:15 AM Post #74 of 80
Hi everybody,
i am also planing to buy an EC3.
I got a question about the headphone jack. Is it strong enough to drive a Philips Fidelio x3?
Is the volume of the headphone jack controllable with remot?
Are USB sticks only supported with FAT32 or also NTFS?
Greetings Daniel
Nov 18, 2024 at 3:49 AM Post #75 of 80
Hi everybody,
Greetings Daniel
For these Fidelio it should be good enough.
You can adjust volume with the remote.
Drive supports all standard formats, we use them mostly in exfat. There is no FAT32 limitation.
