Hi everyone.
Im also having this horrible clipping issue and im seriously pulling my hair out since so far, none of the solutions from this thread (and also from other sources)....
I feel pretty desperate to be honnest
I spent days on this..
Here's what im using
- Desktop quite powerful, i7 4790K, 16 GB DDR3, brand new, 4 days old, 650W cordair power supply : more than enough. I had before an older pc, on which I had exactly the same issues.
NAD DAC 1, it's an USB DAC , numeric / analogic converter, sends wirlessly the signal from one USB transmitter to wifi reciever plugged with RCA cables on Amplifier.
- No specific driver delivered by NAD for this device, recognized as "Generic USB headset" working in 48Khz/16 bits by W7 = all good so far, these are the DAC specs. No ASIO driver as well.
- Reciever and Transmitter are about 3 meters away from each other (specs say it works up to 40meters, so still good here)
- Foobar2k, installed on system SSD (also tried from another SSD dedicated to my softwares)
I have the exact same problem as described in the first post : random clipping / parasites in the sound, variable inensity, from nothing to completely cracking and trashy sound, seems to increase as im using the mouse, or browsing internet pages, but also can appear when I do nothing.
Here is all that I've tried to solve this issue, without success
=> Use Asio4All instead of Windows direct sound
=> increase Asio buffer
=> increase all kinds of buffer i could find in foobar
=> Use WASAPI (push/event, tried both) with SOX2 resampling to fit my hardware 48Khz/16 bits spec
NOTE : With WASAPI, crackles and skipping are very reduced compared to ASIO, less frequent, less intense.
=> Try to locate USB IRQ conflicts with other ressources: i was able to find one of the USC bus on the same IRQ code as my Graphic card.
- However I was not able to locate exactly where my DAC was plugged despite the details found in this topic (i may miss a tip here).
- Anyway,
I basically tried all USB ports of my Motherboard + front panel ones plugged on other specific motherboard controllers , and there
are alot (4 USB2.0 and 8 USB 3.0), and it changed nothing
=> Run foobar with Avast unistalled (did not change anything)
=> Run Foobar with highest processus priority possible from windows processus list & from foobar tick box in preferences
=> Use Asio output while disabling the DAC/USB generic headset in the Windows devices manager
=> Disabling EIST, C STATE and Spread Spectrum in BIOS, as explained in a recent post
=> Read flac file from SSD instead of storage disc
=> Plug the DAC on USB hub with external power supply to clear up any power supply issue.
=> change USB cable
=> Disable AERO in W7
==> and i'm sure im forgetting other attempts i made on other settings...
As I mentioned at the beginning of this post , this pc is brand new, all fresh : new motherboard, new RAM, new CPU; Windows 7 version is different.
Onlly a few things remained the same
Same Graphic card (MSI GTX 760) as in previous PC
Same Hard drives
The NAD DAC 1 itself
The fact that i'm using internal/native motherboard USB ports.
My bad luck.... lol
My last move : I have ordered a PCIe USB 2.0 extension card, to get a new range or IRQ addresses like SodaBoy suggested, and i will plug my DAC alone on it.
I would deeply appreciate any feedback, tip, advice, divine intervention.... to shoot this once for all.
Thanks a lot
