champ
- Oct 15, 2009
Ok before I discovered the Moon Audio cables in my last post, I spent the afternoon doing the same thing tmazer did so I can use a common 3.5mm mini to mini.
Here's what I did:
Buy 2.5mm male to 3.5mm female adapter. Choose one where you can see by the shape that there is quite a bit of the smaller diameter of the 2.5mm to work with before it changes over to 3.5mm. Make sure the plastic is of a type you can shave down with a utility knife. I used this one:
http://www.londondrugs.com/Electrohome-Adapter-3.5mm-to-2.5mm---ELS1/L2978088,default,pd.html
Note that where the plug fits into the headphones it is not a straight line across--so trace the angled path that needs to be cut away.
With the one I got, the outer black plastic is wrapped around an core of clear plastic holding the inner workings together. Once I worked my way to the clear plastic, the black comes off quite easily. Be careful when cutting through to the clear plastic because the wires are not completely protected.
The metal connector is very close to the size of the opening so you may need to cut very close to the plug.
Be sure the top part fits in as much as possible. I got to the point sound was coming from the left and right--but vocals only in the right ear. This told me the connector is not in quite far enough.
Once I shaved away as much of the plastic as possible I realized I couldn't get the adapter in as deep as the original cable. This left some of the shaved away portion exposed. I think painting a few dabs of liquid electrical tape on should cover things up nicely...or just don't over cut away like I did
http://t.homedepot.com/p/Gardner-Bender-4-fl-oz-Liquid-Electrical-Tape-Black-LTB-400/100119178 (this step wasn't done when photos were taken).
Now insert a standard ipod mini to mini. I use a 3ft. length.
Here's what I did:
