gr8soundz
- Jun 28, 2014
Well, one would think the bulk of energy consumption related to transmission power is on the transceiver side, i.e. the source. According to the Bluetooth wiki, the increase in range from higher sensitivity of the receiving class 1 end is minimal.
And btw, the M2's are rated as class 1.
You're right; I hadn't checked the M2 wireless specs: online manual says version 4.0, class 1.
I know first-hand how frustrating bluetooth can be but I've found it fairly seamless in recent equipment (unlike some 10yr old BT devices I still have).
Based on the issue so many are having with the M2, I wonder if the ANC implementation is part of the issue. I thought it strange that the ANC can't be turned off in wireless mode. Makes me think Sennheiser used a combo BT/ANC chip to reduce the circuitry size, cost, and/or get that high battery life (similar to new laptops were you can no longer turn bluetooth and wifi on/off independently).
